Results 1 to 3 of 3
    Senior Member Three Rings e36graduate's Avatar
    Jul 15 2009
    Taxachusetts
    Rs4 Rotor Question
    Looking for the correct name for the little metal spring that sits under the Allen bolt that hold the rotor ring to the hat? Mine are a bit old and wanted to get new ones with the new JHm rings, however can't seem to find them anywhere? The JHM rings come with all the hardwar except these springs!
    Anyone have any idea who sells them?
    Thanks in advance!
    Jul 15 2009
    Taxachusetts
    Making some progress - called H type bobbin
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Id call JHM.
    The bobbin should be size correctly based on the application (like any fastener; screw, bolt, nut etc.). It works like a retainer to give the rotor some play, but not too much.
    definitely post up if you find the specs you need.
