I'm experiencing a plethora of issues with my Audi A6. These issues are mostly suspension pertaining. I'm trying to budget myself with priorities in mind.
First, the steering wheel noise doesn't go away, the sound is more prevalent than ever before. I hope the steering rack is still intact (I did read that tightening the center bolt should help a bit). Not sure about clock spring though, as this issue could be linked to ongoing suspension issues I haven't addressed before (read further)
Here is the steering wheel noise, https://www.youtube.com/watch?v=xcjQ...ature=youtu.be (seems to be a prevalent issue on other Audi models as well)
Second, there is significant play at the 3 o' Clock and 9 o' Clock positions indicating that Tie Rods have to be replaced (likely both inner and outer, appears seized)
Third, The rubber in the upper control arm inserts appear cracked (as in deteriorated), but could not feel significant play (when prying with a pry bar)
Car rocks side to side when going over medium bumps, and goes and up and down evening when running over micro-bumps (small imperfections on the road)
Ironically, my tires are still in great shape in-spite of everything I've experienced here. Where do you think I should start? Parts (including struts) should run me about $500 or so, right?
Sometimes I wonder if its time for another Audi. Timing belt job was done not so long ago as well as front engine seals and serpentine belt. It just doesn't make sense to go with a different vehicle. Engine performs well.
I understand these cars have little to no resale value. There are minor issues with fog light, high beam, and windshield wiper fluid, rear output shaft seal, and flex pipe sections which I have all the parts for (the work is still pending).
What do you all suggest? Thanks!
