Results 1 to 17 of 17
    May 10 2016
    Delaware
    Missing Cover in Engine Compartment?
    Hi, I'm a new owner of a 2017 A4 Premium Plus. When purchasing the vehicle, I test drove and couldn't complete the transaction the day of. I live over 150 miles from the dealership, so we worked everything out over the phone and they delivered the vehicle a few days later. Upon delivery, I popped the hood and I noticed that one of the modules appeared to be missing a cover. I asked my saleslady about it and she wasn't sure. She took a picture, went back to the dealership and then confirmed that there should be no cover.
    Since I don't have a local Audi dealer, I cannot go and check myself. It does however appear to me that there should be a cover and there are clips that would hold the cover in place. It's on the right side of the engine bay facing the car. Pic below, but I don't know if it will show since I'm a noob here.
    https://goo.gl/photos/mzJr1hRBUg3qEhSv7
    Thanks for looking
    Stephen
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Looking at other pictures of the B9 A4 engine bay, it looks like there is no cover for the ECU.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    May 10 2016
    Delaware
    Thanks. It doesn't look right to me, but if that's how it's supposed to be...
    Sent from my SM-N910V using Tapatalk
    Active Member Two Rings SnifflyHealer's Avatar
    Dec 04 2014
    2013 Ducati Monster 696
    Philadelphia
    Quote Originally Posted by gdawg'05a4 View Post
    Ditto, the ECU is out in the open in the B9. Check B8ta's thread a few posts down. He has a good picture of his ECU.
    - Mike
    Current
    2019 Alfa Romeo Stelvio Ti Sport
    Gone But Not Forgotten
    2017 Audi A4 2.0T Premium
    2012 Audi A6 3.0T Prestige
    2006 Volkswagen Passat (B6) 3.6L VR6
    2002 Volkswagen Passat (B5.5) 1.8T
    Veteran Member Four Rings riegeraudi's Avatar
    Apr 16 2009
    That looks retarded. Seriously Audi didn't want to spend an extra 50Cents to finish it off?
    Jul 04 2015
    Ajax, Ontario
    Yes, this is correct this is not covered. I am a trainer for Audi and can confirm.
    Veteran Member Three Rings yb28's Avatar
    Mar 06 2013
    2017 B9 A4 2.0T Quattro DSG , 2017 Q5 2.0T Quattro TIP
    Toronto, ON
    wondering if there's an option or someone makes a cover in the aftermarket :p..
    2017 B9 A4 2.0T Quattro S Tronic | Daytona Gray | Xenon to LED Headlights Conversion | Custom Brembo 8 pot BBK |
    Build Thread
    2015 B8.5 A4 2.0T Tip Black
    2003 B6 A4 1.8T Tip DG
    Veteran Member Three Rings VipinLJ's Avatar
    Nov 23 2016
    Illinois
    The ECU in the B9 doesn't have a plastic cover. And supposedly, it is well sealed. One doesn't have to worry about water leaking in. They probably don't have the plastic cover for better dissipation of heat?
    One of my friends saw the ECU didn't have the cover and washed his engine bay with running water purposely to see if it would short out. But nope. His car runs perfectly. I'm not saying you guys should do it but yes (I don't have the guts to do that to my car).
    2018 Audi SQ5 Prestige - Matador Red, DAP, S Sport pack, 21” V design, CWP, WWP
    2017 Audi A7 Prestige - Glacier White, DAP, Sport pack, 20" BOP, CWP
    2020 BMW 330i xDrive
    Mar 06 2013
    Toronto, ON
    Quote Originally Posted by VipinLJ View Post
    oh i know it's sealed but just saying the engine bay will look much cleaner :o
    Build Thread
    Established Member Two Rings Cadx6's Avatar
    Aug 31 2013
    Illinois
    It's an electronic component. They don't like heat, self generated or environmental. Notice bare metal case, cast in fins, etc. Bad enough it lives in the engine compartment.
    I suppose you could enclose it in some sort of louvered or perforated enclosure but even that will retain too much heat & eventually result in failure .
    2019 Q8 Prestige, Daytona Gray Pearl
    2019 TTS, Daytona Gray Pearl
    Gone - 2018 Q5 Prestige, Ibis White
    Gone - 2017 Q7 Prestige, Glacier White
    Gone - 2017 A4 Prestige, Glacier White
    Gone - 2013 Q7 S-Line Prestige, Orca Black
    Gone - 2013 TTS Prestige, Phantom Black Pearl
    Nov 23 2016
    Illinois
    Quote Originally Posted by Cadx6 View Post
    Exactly!
    Nov 23 2016
    Illinois
    Quote Originally Posted by yb28 View Post
    Looks like your prayers have been answered
    https://www.ecstuning.com/News/Audi_...U_Cover_19468/
    Mar 06 2013
    Toronto, ON
    yes, but I dont need CF for that plus no way im paying 120USD for that ahha..its gunna be close to 200CAD by the time it gets to my house :|
    Build Thread
    Mar 06 2013
    Toronto, ON
    Hey Jason, will you guys make a plastic version?
    CF looks like but looks out of place unless we have some CF intake... plus they have the tendency to turn green due to the heat..
    also wondering about heat getting trapped in the ECU?
    Build Thread
    Apr 05 2012
    Earth
    Gotta have CF because racecar.
    Oct 02 2006
    Wadsworth,OH
    We will not be making a plastic version. We'll also have more carbon parts later on so this is only the beginning :) We always recommend seal coating any carbon that is exposed to heat may it be the sun or engine to prevent discoloring. The ECU is far enough away from any major heat source the cover would not cause the ECU to absorb any additional amount of heat.
    Jason
