Results 1 to 4 of 4
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    Wining noise coming front. Please listen
    When I accelerate I get a wining noise from what I can hear is coming from the front drivers side wheel. Here is the YouTube video
    https://youtu.be/TAhis4MyDP0
    Jan 03 2013
    Baltimore
    Wheel bearing.
    Sent from my XT1096 using Tapatalk
    Oct 01 2014
    Quote Originally Posted by elscotto80 View Post
    Wheel bearing.
    That is what I keep being told. I ordered a kit from ecstunning. Anything else I should order cause I would like my car to be done that same day with all the parts they would need. Also, I go to a german car repair shop where I have to drive a good ways to get there. Would replacing the wheel bearing be something a close by repair shop should be able to do without F%$C*ING up my ride?
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    wheel bearing is a pretty straight forward repair that can be done by anyone with mechanical ability and a shop press (to press the bearing in) I think any trusted garage will be able to do it for you. the kit includes all you need, 4 new bolts and a new axle bolt
    There is a DIY available for S5 which is essentially the same. I debated doing it myelf but I'd still have to get my mechanic to press it in and it just wasn't worth the hassle
