Results 1 to 9 of 9
    Established Member Two Rings Darkangel's Avatar
    Jan 14 2012
    2006 Audi A4 2.0T Quattro
    Keswick, Ontario
    Help. Replaced it, still doesn't work.
    I replaced the lane change module on the passenger side(master) at the back, because I was getting a fault meaning that it was dead.
    Now that I replaced it, I'm getting this message in the dash saying "Lane Change Limited Functionality"
    I scanned it, found this:
    Address 3C: Lane Change Labels
    Control Module Part Number: 8K0 907 566 A HW: 4L0 907 566 B
    Component and/or Version: J0769_SWA_MasterH01 0020
    Software Coding: 0000102
    Work Shop Code: WSC 06335 000 00000
    Additional Info: 8K0907568A J0770_SWA_Slave_H01 0020
    Additional Info: Geraet 00000
    VCID: 356525E72781
    2 Faults Found:
    00447 - Function Limitation due to Over-Voltage
    001 - Upper Limit Exceeded
    00532 - Supply Voltage B+
    What do I need to do now?
    Quartz Grey 2009 Audi A4 Quattro
    Unitronic Stage 2
    R8 red coil packs W/ NGK Platinums
    Stasis turbo-back exhaust
    K&N intake
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Do you have old scan from your old module with fault ?
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jan 14 2012
    Keswick, Ontario
    Quote Originally Posted by Gunnark100 View Post
    Not here right now.
    It's saved in the VCDS logs in my laptop.
    Oct 21 2012
    Earth...
    Not sure, if its fully related, but by manual, did you calibrated system?
    Jan 14 2012
    Keswick, Ontario
    How do I do that?
    Unitronic Stage 2
    K&N intake
    Oct 21 2012
    Earth...
    I belive you need dealer for that:
    http://www.audi-portal.com/en/diagno...u_12999.html#1
    http://forums.ross-tech.com/showthre...-Retrofit-DONE
    Could be thats why you getting those voltage errors etc...if you hit on this module basic settings, result is what? But probably no use anyway, as it has no correct info from your car, just old settings, but you can try... No other faults under any other module?
    Jan 14 2012
    Keswick, Ontario
    No, there's no other faults anywhere else.
    I guess I have to make a trip to the dealer
    Oct 21 2012
    Earth...
    Probably yes and as far i know its a expensive procedure....sry!
    Jan 14 2012
    Keswick, Ontario
    Great
    Thank you for the help though.
    Unitronic Stage 2
    K&N intake
