Results 1 to 21 of 21
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Questions Regarding the use of the TTV B7 RS4 --> 2.7T Flywheel
    When I'm doing my build, I'm highly considering going with a TTV Steel flywheel and B7 RS4 clutch setup. However, through some research, there seems to be a debate on what flywheel bolts should be used and clearance issues.
    For my setup, I'll be going with the following:
    • TTV 2.7T to B7 Steel Lightweight Flywheel
    • B7 RS4 LUK Repset
    • Clutchnet Disk (Either full faced Feramic, Kevlar, or 6-puck**)
    Should OEM bolts suffice in this situation? Any clearance issues with the crank due to bolt length, or the clutch disk itself?
    **All are around the same price. Looking for the best disk that will offer smooth engagement but still be able to hold a launch. Opinions? Obviously a 6-puck disk would be able to hold more power, but at the expense of driveability. The car will be making E85 K24/RS6 with rods power but this setup should be sufficient without breaking the bank.
    I do know a lot of people would recommend the AMD or JHM clutch combo, but from what I can see, both setups are B7 RS4 Pressure Plates (with AMD's being modified for B5 flywheel use) and an upgraded disk.
    Thanks in advance
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Jun 08 2014
    Vancouver, Washington
    In for info. Planning to use the same setup for my 6mt swap, except using the disk that comes with the repset since im only stage 2.
    Jul 07 2009
    Alberta, Canada
    It's always best to check clearance when you install.
    Just cut the OEM bolts down if need be.
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    OEM bolts....
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    what wrong with the ringer racing stage 4 clutch?
    FWIW I have a 6 puck in my car.. Yes you have to slightly change your driving habits for longevity reasons(25k on my FX400 6 Puck) but has held up to a lot of abuse on and off the track.. Over 50+ launches and more NLS than I can remember..
    That being said RR stg 4 clutch will probably be my next clutch..
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by Shhmaudi View Post
    B7 RS4 LUK repset is only $130 lol
    Justin
    #YEengineering
    Oct 27 2011
    TOYS
    Philly Suburbs
    I think you will regret going with a factory B7 rs4 clutch kit, I would do a Southbend Stage 3/4 or an AMD Stage 3+ if your motor is getting rods.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    FYI I have a RS4 based ceramic kit for sale in the FS thread. Great option to save some money.
    Aug 24 2014
    Newport Beach, CA
    What driving habits did you change to get more life out of the clutch?
    2024 M3 Comp xDrive
    Dec 10 2013
    Borden, Ontario, Canada
    You will use OEM hardware. For everything regarding this flywheel and clutch kit. I asked the same question a couple weeks ago
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Sep 11 2007
    Tampa, FL
    It can be done, but ceramic is not meant or designed to "last long" it's designed to hold torque. That was the reason for the development behind hybrid materials i.e. Feramic.
    The only way to get Ceramic to last is for quick engagement or limiting slip. Most people wear it quickly trying to slip the disc to allow it to feel more street able.
    Mar 01 2014
    Los Angeles, CA
    From what I've read, isn't the AMD kit just a modified B7 RS4 PP with upgraded disc?
    I'd be upgrading the disc either way.
    Justin
    #YEengineering
    Jul 23 2012
    Pullman, WA
    Quote Originally Posted by Wagonholic View Post
    +1
    From what I have gathered, the AMD kit is a b7 rs4 pressure plate (painted), with a 6 puck disk.
    Sep 11 2009
    NE
    AMD kit is B7 RS4 pressure plate with two modifications to it:
    1) modded plate, rivets and straps so it fits B5 FW
    2) modified diaphragm to exert more force
    If your goals are modest torque, you'll probably be happy with TTV B5 FW with B7 top and stock B7 RS4 PP + some more aggressive disc. However, K24 + E85 is not "modest". That can easily put out 600WTQ / 750 crank TQ which will overwhelm everything but top notch TQ holding offering from AMD or dual/triple clutches.
    My set up is tial 770 with logs showing slightly north of 600WTQ in coldest winter to wheels, it is happy with AMD stage 3 set up which is "fibertuff" full disc, which means eight large pucks of friction material on a full face plate. They have two more aggressive set ups. Stage 3+ which is the same but the pucks are feramic (or ceramic, I forget) and then lighter 6 puck disc that has the most holding capacity.
    I love my set up, it is by far the best clutch I ever had and I went through quite a few setups, including twin disc which was a horrible to drive thing.
    Mar 01 2014
    Los Angeles, CA
    I ended up picking up a Southbend Stage IV extreme since I got a really good deal on one. Should be plenty for my needs.
    However, I feel some good information has been said in this thread, so I hope it's a good resource for people who do plan to do a B7 RS4 setup. Considering it's only about $130-140 for a LUK repset from RockAuto, it can be a pretty good bang for your buck clutch setup.
    Justin
    #YEengineering
    Jun 08 2014
    I'm very glad Bordom told me about the Repset. I was about to spend $400 or so only for a B5 OEM clutch kit. Now I have more to spend for my TTV flywheel with the b7 repset :D
    Oct 27 2011
    TOYS
    Philly Suburbs
    A factory B7 RS4 pressure plate does NOT bolt up to a factory style B5 flywheel!!!!
    The AMD modified B7 RS4 pressure plate will bolt up to a B5 Flywheel.
    Apr 21 2013
    Longmont, CO
    Nobody said it does. TTV makes a b7 style flywheel for us.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Didn't know that, sorry.
    Sep 11 2007
    Tampa, FL
    Correct so ideally you would want a TTV single mass steel flywheel and a factory RS4 clutch kit with disc of choice.
    Dec 10 2013
    Quote Originally Posted by MarlinFoundNemo View Post
    You're welcome!
    IG: 24_et
    Sold:
    RIP:
