Results 1 to 2 of 2
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    C7/C7.5 Technical Service Bulletins (TSB) Database
    Can we have comprehensive TSB database? Seems like these cars have many TSBs that owners can benefit from. I'll start with two that i had performed recently. We should keep posts short and to the point so TSBs dont get burried in the text. Please list year and model of the car. I'll try to edit first post with all the additions.
    TSB 2034000/4 Side Assist Software Update - 2013 S6 - After side assist gave error and shut down
    TSB 2036167/2 Turbo Coolant Lines Replaced - 2013 S6 - After coolant leak
    TSB 2039267/1 - TCU SW Update - 2013 S6 - Jerky downshift 2>1
    TSB 2035235/2 - ECU SW Update - 2013 S6 - Throttle response issue
    TSB 20350491/1 - TCU SW Update - 2013 S6 - Jerky downshift 3>2 in S mode
    TSB - Rock Guard Install - Rock puncturing radiator, coolant leak (https://www.ecstuning.com/Audi-C7_A6...3.0T/ES451372/)
    TSB 2036392/1 - Software Update for Engine Mounts - Shaky at 500-1000rpm (http://www.revbase.com/BBBMotor/TSb/...dPdf?id=183808)
    TSB 2036558/1 - Replace Secondary Air Pump - Fault: Secondary Air Injection System Insuficient Flow
    '23 Tesla Model X | '17 Ducati Supersport S
    Feb 10 2011
    MotorCity
    Updated with more TSBs
