Results 1 to 4 of 4
    Aug 04 2014
    2014 S7, 2003 A4 3.0, 2007 A6 4.2 (Sold)
    Ohio
    P0087 Hard Starts
    So a few days ago I went out to my car to go to class and it cranked for a lot longer than usual then stuttered when it finally started. Eventually it settled down and it drove fine. On my way back home the check engine light came on but it still drove just as normal. I thought it was a one time deal so i scanned for codes and it came back P0087 “Fuel Rail/System pressure too low” so i reset it and it came back the next day and every day after that. It only does it after it sits overnight. The fuel filter was changed less than a year ago and I’m leaning towards a hpfp but before spending that $$ i wanted to see if anyone else had the same experience. Its a 2007 4.2. Thanks!
    Saturday,07,May,2016,16:09:47:58493
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 15.7.4.1
    Data version: 20160216
    www.Ross-Tech.com
    VIN: WAUEV74F07N084717 License Plate:
    Mileage: 212380km-131966mi Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
    52 53 55 56 61 62 65 67 6C 72 76 77
    VIN: WAUEV74F07N084717 Mileage: 212380km-131966miles
    Address 01: Engine Labels: 079-907-560-BVJ.clb
    Part No SW: 4F1 910 560 A HW: 4F1 907 560
    Component: 4.2l V8/4V 0030
    Revision: 74H03--- Serial number:
    Coding: 01050009190F0120
    Shop #: WSC 03200 444 82880
    VCID: 2149A793F82D973651-8074
    2 Faults Found:
    000135 - Fuel Rail/System Pressure
    P0087 - 008 - Too Low - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 212027 km
    Time Indication: 0
    Date: 2016.04.28
    Time: 13:06:50
    Freeze Frame:
    RPM: 2500 /min
    Load: 63.5 %
    Speed: 46.0 km/h
    Temperature: 88.0∞C
    Temperature: 33.0∞C
    Absolute Pres.: 980.0 mbar
    Voltage: 14.224 V
    P0087 - 002 - Too Low - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 212039 km
    Time Indication: 0
    Date: 2016.04.28
    Time: 16:53:43
    Freeze Frame:
    RPM: 3857 /min
    Load: 96.8 %
    Speed: 119.0 km/h
    Temperature: 96.0∞C
    Temperature: 31.0∞C
    Voltage: 13.589 V
    Jul 17 2011
    Sin City, USA
    Do you hear the fuel pump prime when you open the driver door?
    '09 C6.5 A6
    Aug 04 2014
    Ohio
    Yes, you can hear it prime when you open the drivers door and when you turn the key to run.
    Dec 08 2014
    United States
    Did you ever get this resolved?
