Yes, for vacuum lines just use silicone tubing. I like the stuff from siliconeintakes because its thick walled (doesn't collapse under high vacuum or expand under high pressure) and being silicone it doesn't dry rot.
SS is nice when you have corrosive chemicals (due to a teflon core) or high pressure fluid systems.
but for the one that connects from the overflow tank to the hard line, that has several bends, would I be able to safely just use an adequate length of silicone tubing? Same for the rest of the lines that just use standard hose clamps?
I use silicone hoses for my overflow tank and for my turbo lines. Works just fine and silicone is generally more resistant to the heat. Just make sure they are the correct length. Too long and they can kink, too short and they might pull off.
P.S. Would running silicone couplers with aluminum tubing be acceptable in the various systems of this motor?
Yes, I would assume so as long as you connect them all correctly. I plan on replacing my coolant hard pipe with aluminum piping and couplers. Only caution with replacing the hard pipe is making the seal for the coolant temp sensor housing. If you have access to a TIG you can get the aluminum housing and weld a different flange to it though.
