Ok so i bought this b6 avant. Drove it about 50 milles check engine light came on. Had my mechanic scan it the caught a code for a misfire however the motor shows no vibrations and runs normal. Previous owner said it has an apr tune and had reciepts for recently done. Timing belt and rollera. Water pump kit with collant pump, ignition coils, spark plugs and connector kit, cam shaft tensioner, timing Chain, solenoid and gaskets. Does anyoneeeeee have any ideas on what the issue is
