Results 1 to 10 of 10
    Jul 21 2015
    B6a4 power advice, which way to go.
    Didn't look too hard for threads like this but I Daily drive a b7, picked up a b6a4 1.8t for fun. Just looking for the most power I can get out of it and it still be reliable all while keeping costs down. I can wrench so I won't have to pay much shop labor, if any. What kinds of build do you guys recommend? several options out there but what to do... Just seeing what things you guys are running on here, also what kind of awhp and tq you guys are putting down. It would be a huge help. Thanks AZ
    Veteran Member Three Rings VenomGT9's Avatar
    Dec 09 2014
    Chicago
    BT kit...can make decent power on stock internals
    Searching for my next Audi...
    05 Black G35 6MT- ARK / HOTCHKIS / EiBach / AAM
    98 XJ 4.0 4x4
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    Jan 01 2012
    2004 A4 Avant
    CO
    ^^^this.
    Aug 26 2005
    A mild tune like APR stage 1 or 1+ is the limit for the stock bottom end parts, while retaining reliability and smooth driveability for a daily street driver. The APR K-04 upgrade software is also worth considering for a daily driver, but has a sharper edge to the setup. A BAT will require bottom end build up, and will not have the right type of performance characteristics optimized for a fun to drive daily street driver. A setup and tune with the lower half of the RPM range providing best torque and performance and good drivability is the best setup for the daily street driver.
    Vorsprung durch Technik
    Jul 21 2015
    I'm gonna do the GTRS kit, most ideal and bang for your buck seems like. Also looks like it has good potential for power. Thanks guys 👍
    Jan 01 2012
    2004 A4 Avant
    CO
    I'll go ahead and recommend a motoza tune also. That's what I run on my GTRS setup and its solid. 28k daily driven miles before it was no longer a DD and the only problems I had were the coolant lines. I would recommend not using the coolant lines from the GTRS kit, mine became hard a brittle and weeped coolant from the banjo fittings even with a double one time use clamp install. Also don't use the exhaust gaskets that come with it, grab yourself some OEM ones.
    Aug 26 2005
    Quote Originally Posted by VenomGT9 View Post
    Can make decent power on stock internals for how long?
    The AMB rods are fused powdered metal, not forged steel.
    The AMB pistons are a light weight casting, designed specifically for the ULEV emissions certification, not beefy forgings used on earlier 1.8T versions. The BEX and BAM 1.8Ts (and others,) are built with forged internals strong enough for significant power increases while retaining long term reliability.
    Search here on AZ and on the web for stock internals AMBs with tunes and BATs, suddenly developing unique custom engine block ventilation, aka grenaded AMBs.
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    for engine block ventilation..
    Ed
    why say lot word when few word do trick.
    Aug 26 2005
    Quote Originally Posted by elewsader View Post
    "The trouble is, you think you have time - Buddha".
    I thought there was a subtle catch in the fundamentals somewhere...
