Originally Posted by
pbudra15
Thank you! Agreed that the material is relatively cheap, but the labor is an absolute nightmare. The gentlemen who did it, had the car for about a week and a half and spent roughly 35-40 hours on the car. He's a perfectionist and gave me a much better price than the typical prices I listed above.
He was able to wrap it well enough where you can't find one seam on the whole car, and that's what really stood out in the final product and probably the reason it's mistaken for paint so often
Sorry, but a lot of inaccurate information being thrown around regarding vinyl wraps.... let me shed some light on the issue.
An A4 will likely use a full roll of 60" material, some adhesive promoter, along with specialty tools; felt tipped squeegee, propane torch, masking tape, exacto, etc. Depending on color/texture and brand - Avery vs. 3M, the only brands I would consider - you're looking at ~$600. *This excludes any type of laminate that your specific material could need.
As far as labor goes, it can be tough to estimate based on one huge factor, experience. If I saw a quote stating 40 hours, I would go to the next guy. Wrapping a full car - especially one like ours that has very few complex curves - should take an experienced installer about 15 - 20 hours, tops (or 2 guys 8-10 hrs.) A good wrap shouldn't have any glaring seams, and I would expect that kind of attention to detail if the person doing the job has dealt with luxury cars in the past (read, enthusiasts). Your market will also have an impact on price. I'm in Seattle, for whatever that's worth.
I would shy away from wrapping the door jambs - its a lot of work that wont really pay off as you hardly ever see it, unless the door is ajar of course. To do it properly, you would have to take the doors off, and even then, what a nightmare!
And last, durability. I've taken wrapped cars through drive-through car washes plenty without any issues. The concern is a hard edge that pressurized water can get under, which also applies to dipping (this is why adhesive promoter is used in certain areas). As for brushes, well, any soft surface can be marred if enough pressure is applied. In my experience, Dip will not last anywhere near as long as vinyl. Good material is typically warranted by the manufacturer for ~4 years outdoor use. Have you seen dipped cars after just one or two years? ...its not pretty.
Anyhow, for those thinking about wrapping your car, shop around. You should be able to get a quote for ~$2,500! And do ask to see previous work.
This is an industry where not everyone's standards are the same!
