Results 1 to 10 of 10
Thread: Fuel pump wires
    Established Member Two Rings sxC's Avatar
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    Fuel pump wires
    I've read on here that the Bosch 044 fuel pump install requires you to flip the black and red (as in black to red and red to black) because Audi colors their hot wires differently. Does anyone know if this is the case with the pump that comes with the JHM tune and fueling? I'm not sure what model it is but it says DW300 on the side.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by sxC View Post
    The AUDI wiring off the harness in the tank Black is +12V (fuel pump relay), faded Brown (looks red) is Ground. If you notice, Audi likes to use brown wiring for all its ground wiring, so this makes sense if you are familiar with Audi wiring.
    So make sure:
    Audi Black wire goes to the +12v side of the fuel pump wiring (any pump)
    Audi Brown (when faded it looks redish) goes to ground side of fuel pump wiring (any pump)
    Aug 25 2012
    Elmore alabama
    That is correct. Red to negative and black to positive. My deutchwerks dw301 has marking stating which is positive and which is negative as well.
    Jul 04 2012
    Woodbridge, VA
    The 044 is stamped. Red is 12v, blue is ground on the pump itself. If I were you, I'd simply hook up a multimeter or even test light to check positive wire going to pump. Takes 10 seconds tops and peace of mind when you go to start the sucker and it doesn't work. You'll know you got the wires correct.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by vavJETTAw36 View Post
    The 044 is stamped. Red is 12v, blue is ground on the pump itself. If I were you, I'd simply hook up a multimeter or even test light to check positive wire going to pump. Takes 10 seconds tops and peace of mind when you go to start the sucker and it pumps backward. You'll know you got the wires correct.
    fixed, its confusing as hell when you hear the pump running but get no fuel pressure, so figured I'd clarify.
    Jul 04 2012
    Woodbridge, VA
    Good catch! You really wouldnt know wtf to do if it was running but wont start.
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    Thanks for the help! I figured I just didn't know if this applied to all fuel pumps or just the 044.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    Like Monty ... I found out the hard way
    01.5 Imola S4. Stage 3 F21's/To much to list
    May 16 2008
    WA
    All, since its on the car end not the pump end.
    +1
    Brown = Earth(think, 'dirt') = Ground
    Thats how I remind myself when working on the audi
    Jul 05 2024
    Sweden
    Has anyone of you experienced “fried” wiring to the fuel pump?
    New pump and relay’s worked fine for 2000 km and then died completely.
    Audi A4 1.8 T avant 2002 with only 70000 km.
    Where do the fuel pump grounds to the chassi?
