Results 1 to 2 of 2
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Abs module coding
    So ive looked around but i dont see anyone that has coded their abs modules after they do the b5s4 brake upgrade to the a4. Im assuming that coding the module after the swap will adjust the proportioning valve. The rosstech wiki has info on coding it but has anyone done this. Ive gone from standard a4 brakes to the lucas hp2s but im also thinking about going to the brembo 17z/18z. And still never see anyone recode the module. Heres a link to the wiki about coding tbe module http://wiki.ross-tech.com/wiki/index...SR/ESP)#Coding
    Senior Member Three Rings UCFQuattroguy's Avatar
    Jul 05 2005
    '01 Audi A4 TMQ
    Orlando,FL
    Not sure the A4 modules can be re-coded. i think it was specific to the ABS Controller module on *some* S4s. Hopefully somebody else can confirm or correct that statement.
