Results 1 to 17 of 17
    Jul 10 2014
    Any Leads on a Good Shop to Paint Calipers?
    Need Calipers painted Red... anyone know a good place? I'd like it done as OEM as possible...
    Veteran Member Three Rings UltraS4John's Avatar
    Sep 16 2006
    2013 Audi S4
    Northern VA
    I wouldn't mind painting mine red either.
    2013 Audi S4 - Brilliant Black (Prestige) DSG + IE Stage 1 & STaSIS exhaust
    2013 VW GTI - Carbon Steel Gray Metallic DSG + APR Stage 1 & AWE exhaust
    2018 Audi Q3 - Daytona Gray Pearl DSG
    Sep 21 2014
    Baltimore Maryland
    APAC in linthicum heights.. Although anyone can do it. I have done my own with great results.
    I did back Subaru STi brakes from black to yellow on my legacy.
    2014 Audi A6 3.0t
    2015 Audi S4 DSG
    APAC does great work. We work pretty closely with them. Im not sure if they do the work or if its their powdercoater , but they also offer vinyl wrap for brake calipers. They also clear coat over the vinyl. The examples I have seen look great.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Ed, Will Vinyl really hold up to that much heat? I'm shocked they are using vinyl for this kind of application. usually use a high temp paint like G2 haha... but if you say it's safe, i trust ya
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Paint or powder?
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    I cant say Ive seen the long term to vouch for it, but they do. It is evidently a "high temp" resistant vinyl and with the clear coat it looked great.
    The company is called BMore Kreative ....http://www.bmorekreative.com/
    I might give it a try
    Sep 21 2014
    Baltimore Maryland
    My concern about vinyl would be more about it holding in heat... But not sure if it's an issue because the real heat buildup should be in the rotor.
    2014 Audi A6 3.0t
    2015 Audi S4 DSG
    Jul 10 2014
    Looks like this is a 2-3 day job...
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Quote Originally Posted by Silverarrow240 View Post
    For powdercoating, probably.
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    best is to just paint it yourself. couple hours and you're done.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    powdercoating looks better than paint, especially in the long run. There are plenty of places in DC area that can do that.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by ed@4induktion View Post
    Brandon is the best !!!! Check out his work... He did some work for me and it was top notch
    Nov 29 2013
    Silver Spring, MD
    Hmmm, I'd be interested in doing do them for my rears (I like the idea of being able to remove them later).
    Ed - Does APAC do the work and just uses BMore? Or do you take it straight to BMore?
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Sep 21 2014
    Baltimore Maryland
    APAC does their own work. It's a full function pimp your ride kind of place that does fabrication and paint.
    2014 Audi A6 3.0t
    2015 Audi S4 DSG
    APAC paints calipers ( I believe), but the vinyl wrap is BMore. I spoke to them yesterday to get a few answers. You would need to bring him the calipers and it would take about a week. It is about $170 for a set ( $340 for all 4 ) probably depending on exact color choice. The clear is powdercoated on.
    Nov 29 2013
    Silver Spring, MD
    hmm, i kinda need my calipers....lol.
