Results 1 to 6 of 6
    Senior Member Three Rings brooklynA42004's Avatar
    Jan 10 2014
    2005 s4, 2004 a4 1.8T, 2010 Mercedes AMG E63, 2005 Tahoe Z71
    New York
    Can't reset CEL on 3.0
    02 3.0 CEL light came on and I can't clear code! hooked up my generic scanner says code cleared but CEL still on, disconnected battery still on! any other way to clear CEL?
    2004 A4 2004 1.8T - DD Dolphin Gray
    2005 S4 Silver
    2005 Tahoe Z71
    2010 Mercedes AMG E63 Steel Gray
    Raptor 660 - KFX 400 - DS250 - 250EX
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    What's the code? It's probably recurring as soon as you clear it.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Fix whatever is causing the code, then clear it.
    Jan 10 2014
    New York
    well I went to get my car inspected and while waiting online (long line) my battery light came on still passed inspection but about 5 mins after I passed got my sticker I got code 18032 TC :( I was thinking this code was due to the battery and wanted to reset it to see if it comes back, also had code 18010 weak battery. I was on a 250 mile road trip and everything is working fine just the CEL
    2005 S4 Silver
    2005 Tahoe Z71
    Fry Sauce, UT
    Do you have an automatic? I believe 18032 is usually paired with something in the TCM (I've seen it paired with torque converter codes). Do you know anyone with VCDS so you can do a complete scan?
    Jan 10 2014
    New York
    Quote Originally Posted by agentsmith988 View Post
    Yep automatic, I'm going to drop it off later today.
    2005 S4 Silver
    2005 Tahoe Z71
