Results 1 to 16 of 16
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Traction Control light + power loss when banking right.
    As the title states, whenever I'm at highway speed and taking right curves my ESP kicks in and I'll get momentary loss of power. It doesn't happen if I turn ESP off before taking the turns. It doesn't generate any codes but it is very worrisome. Any ideas?
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Just to be clear, you are actually checking for codes and not just referring to not getting a CEL?
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Correct. No codes are reported via vagcom. Though a while back I did get a code for the ABS sensor That lit up the ESP, brake and traction control light. I cleaned the sensor and it has only come up once in the past year.
    Also, my title is wrong. It's not the ESP light. It is the traction control light.
    Dec 28 2006
    Western Maryland
    I suspect your problem is coming from an erroneous reading from one of your wheel speed sensors. I't either reading too high or too low. The ESP is reading it as the car getting out of sorts (wheel spin) and starts to cut power a little. I would recommend that you watch the wheel speed sensor inputs in real time and see if that confirms my suspicion.
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    I suspect your problem is coming from an erroneous reading from one of your wheel speed sensors. I't either reading too high or too low. The ESP is reading it as the car getting out of sorts (wheel spin) and starts to cut power a little. I would recommend watch the wheel speed sensor inputs in real time and see if that confirms my suspicion.
    Will do. Good call. Thanks Fletcher.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by treysgreen View Post
    Here's a really neat "walk through" for anyone who wants to monitor the wheel speed sensors: Clicky click®
    Junior Member Two Rings
    Oct 31 2012
    Connecticut
    Just started to experience this problem. I am in the middle of diagnosing but suspect it could be the result of overly worn tires or uneven tire wear causing wheel speed sensors to not read evenly or within their expected limits.
    Veteran Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    I have had the exact thing happen to me... I have 2 sets of wheels. 19" with all the same tires and wear, and 16"oem with 3 different tires and wear. When I run the 16" at highway speeds and turn I have the light (TC I think) and loss of power. With the 19" wheels there is no light nor loss of power, so long time ago I switched back and fort the wheels to test if it was the uneven tires. I concluded after the test my problem was the tires. So this might be something worth looking at on your car.
    Comp6262, IECVA2 cams, ID1000cc, 70mm TB, 044pump, Maestro7
    Oct 31 2012
    Connecticut
    Quick update. I just threw brand new Blizzaks on my car and the issue has stopped happening. Will continue to monitor and update.
    Aug 13 2015
    LA
    This link returns a 404. Id like to do this but it’s dead.
    I’m also having an issue while driving too at highway speeds (50+), turning slightly to the right into a curve while pressing on the gas, the traction control light blinks and I lose the ability to accelerate. If I press the gas, nothing, when I release the gas and straighten out the steering wheel and press the gas again will I regain control and able to accelerate.
    I tried the Steering Angle Sensor (G85) Alignment on the VCDS and I was still getting the blinking traction control and loss of power.
    Sometimes I’d get a feeling of braking when I turn into a right curve and the traction light blinks. That was a new issue.
    Any things I need to check?
    Dec 28 2006
    Western Maryland
    You will need VCDS to monitor the wheel speed sensors in real time. Additional info in this thread Clicky click®️
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Quote Originally Posted by cleoo View Post
    Are you Front Trak by chance (Front wheel drive)?
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, Frankenturbo F4-H Kit, Bosch EV14 550cc injectors, APR R1 Diverter Valve, Snow Performance Stage 3 Water/Meth Injection Dual Nozzle Setup, Majesty FMIC kit, SSAC Cat Back Exhaust, Podi Boost Gauge in center vent pod, ATP Test Pipe, K&N air filter, HID fog upgrade, eBay short shifter, Center LCD retrofit, Aero wiper kit, Eibach Pro-Kit lowering springs, 18” B6 Ultrasport, Firestone Indy 500.
    Aug 13 2015
    LA
    Yes. Front wheel drive.
    Nov 13 2009
    I find that any Front Track cars I test drive always has the traction control light turn on when I get on the throttle and there is any slippage whatsoever.
    Aug 13 2015
    LA
    I monitored the wheel speed sensors on the ABS module on VCDS but I didn’t really noticed any drastic difference among the four sensors. Maybe one was a tic slower than the others but definitely not the front left, I suspect, was causing the power loss.
    I haven’t tried the cleaning of the wheel speed sensor yet from the link old guy sent.
    Aug 13 2015
    LA
    Resolved: A torn inner CV boot was the cause of the issue. It leaked a lot of grease and caused a mismatch apparently.
    Replaced the axle with another one and the blinking ESP and the sudden ABS braking went away.
