Results 1 to 9 of 9
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Non-OEM wiper blades
    So I've been using Valeo 900 series blades on my B7 and have been met with somewhat mixed results. First set was excellent, second not so much(drivers blade leaves streaks). Now, with that all being said, I need to replace the blades on my C6. I'm not going to go with the Valeo blades, so I was set on getting the Bosch OEM set for $31 on Amazon. However, I found another brand that I've never heard of before on Amazon that I'm willing to give a shot. The blades are just under $9 a blade, so what the hey? I live where it doesn't rain all that much, so I'm willing to trying these @ less than $18 a set. Any one else ever heard of these?
    http://www.amazon.com/AUTOHAUX-Seaso...2%3A1248861011
    ...NVM I don't think these will fit haha. Looking closer at the pics, the hooking mechanism is different.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Apr 07 2010
    2019 A4, 2018 Subaru Outback
    Southington, CT
    Those are "J" hook wiper blades and the C6 does not have "J" hook wiper arms so they will not work. I have not found any non OEM blades for the C6. I have purchased these:
    http://www.amazon.com/Bosch-33971189...ype=automotive
    or I buy the blades from genuineaudiparts.com. About the same price from either.
    The ones at this link are note quite right for the later models because for some reason they have slightly different (~1cm) length left and right blades.
    If anyone has found less expensive blades for the C6 please post.
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    I have bought the Bosch ones in the past too, seem to last 2 years or so before needing replacement. I don't know of any alternatives because of the weird mount they use.
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    May 17 2009
    Idaho
    Quote Originally Posted by ManyAudis View Post
    That's what I ended up getting, but for less through Amazon warehouse deals because they have a few with damaged packaging.
    Current:
    2002 1.8t A4 Sedan
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    Can't go wrong with these:
    Amazon
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by kocyk123 View Post
    Amazon
    These X2, no noise/chatter... Seem to last two years or so.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    May 17 2009
    Idaho
    Got those in yesterday, popped right in and g2g. Paid $23 for a brand new set in slightly crushed packaging. Amazon WHD FTW.
    Current:
    2002 1.8t A4 Sedan
    Jan 30 2014
    1st gen Q45s
    FL, USA
    Quote Originally Posted by c@@kieMonsta View Post
    glad you scored. curious: were the ones you took off VAG? they (OEM) are 7mm different between left and right. which is likely in the noise, but since the blades you put on are 2 of the same, just curious if you have differences in swept pattern (right or left)?
    May 17 2009
    Idaho
    Quote Originally Posted by FL C6 Avant View Post
    Too early to tell. Just installed them, but haven't had the opportunity to use them.
    Current:
    2002 1.8t A4 Sedan
