I recently picked up a automatic 1999 a6 Quattro 2.8 with a "bad transmission". Reverse works great, but when in any forward gear the car will creep forward about a foot when giving it gas then won't move any further.
Jacked the car up and put it in drive and only the rear wheels spun and then I gave it gas and all four were rotating. (If that matters)
All gears on the dash light up individually when selected.
When I opened up the fill hole on the transmisson about a liter of transmission fluid came out of the fill hole. (Car was level) no metal shavings or chunks were present. The transmission fluid that came out was dark red?
when I try to scan the car with a obd2 scanner it says "waiting for vehicle to respond and then times out?
Also sometimes when I start the car it will die right away unless I give it gas?
Oh and the brake light is flashing and the abs light is on.
Sorry I do not know too much about cars. All or any help is appreciated.
Thanks.
