Results 1 to 40 of 53
    Jun 08 2014
    Vancouver, Washington
    MarlinFoundNemo's Manual Swap!
    Ladies and Gentlemen. The time has come, after 3 long hellish years, to 6mt swap my B5. Now, I won't be swapping until July (due to school and working), but I will be collecting parts and researching my ass off until then for this. I am graduating high school in t-minus one month exactly, and this is my grad present for working hard. Take notes kids ;)
    The swap. All I'm missing is a clutch/fw/pp combo, and two front axles. I'm going to be stage 2 for some time to come still, so I will be going for a mid-range setup with those.
    Did I mention it came with a JHM trio, updated 1-2 collars, and 034 TD mounts? :D Only 2k miles on the rebuild too!
    Also, another small side project. Got this "Euro" (prefacelifted) trunk and I'm in the process of painting it! Filled in two dents, and its all primed ready for paint!
    I will have many questions to come but to start off heres a few.
    What clutch/fw/pp combo should I go with??? I'm thinking a LUK RS4 OEM pp/clutch with a fidanza flywheel? I've heard good reviews of both.
    Can I completely swap in a 6-speed harness and not have to splice/wire in clutch pedal switch/reverse lights? I have a harness too.
    Thanks in advance!
    EDIT: OKAY GUYS I WONT DO FIDANZA
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    TTV flywheel with AMD stg3 clutch seems to be the crowd favorite. It performs well and has longevity under its belt. And I think it's way easier to cut and splice.
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Hell yeah! I really liked that Valeo single mass flywheel conversion I had. And at only $550 iirc with clutch, pp, and flywheel. It held my stage 2 power perfectly.
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Jun 08 2014
    Quote Originally Posted by Peter1.8t View Post
    Hmmm I'm not THAT rich yet ;) Trying to keep this whole swap under 2k haha. Pulled this off another thread but is this everything that needs to be spliced?
    Clutch Cruise Switch -> Pin 39 ECU / Ground
    Reverse -> Blue/Red / 12v Switched
    Clutch Start -> Relay 53 Brown/White / Ground
    Quote Originally Posted by CJ_ View Post
    Yup, $550 and its really looking like I'd go with this one. All good "OEM" parts, great price, and everything I need in one package.
    Jul 04 2012
    Woodbridge, VA
    Do not get fidanza. Clattery and chance of early failure due to premature tone ring detachment... I bought a car with it installed and I can't wait to change it.
    Dec 10 2013
    Borden, Ontario, Canada
    Just buy the TTV Flywheel. It's ridiculously adorable
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Dec 03 2009
    PNW, Washington
    If money is an issue then TTV flywheel and see if rockauto still has some rs4 clutches. Fidanza is a big no no on b5's. When it comes to labor intensive work like this, I'm a fan of doing it right the first time with the right parts. If that means saving up a little extra money to do so then so be it. Not sure about you guys but I strongly dislike trans pulls.
    This is mainly if you have any plans to go bigger turbo/ more power down the road I might leave yourself some headroom with the clutch torque limit.
    Jun 08 2014
    Nooo I'm not doing the fidanza. I think I am going to do the valeo kit. I know valeo makes good stuff and I trust CJ's reviews. I will be stage 2 for a few years and thousands of miles to come. When I do my K24 RS6 build, I will put some higher end parts in there.
    Dec 03 2009
    PNW, Washington
    Valeo is a good option. It will hold nicely for what you have planned over the next couple years.
    K24'a are another debate, but I would suggest skipping those and doing k04's if you keep the stock block. E85 and rods is another story. I've beat up on several k24 cars around here with k04's on the s4.
    Dec 10 2013
    No fun with F21's?
    IG: 24_et
    Sold:
    RIP:
    Jun 08 2014
    Oh yeah I wouldn't do it without rods and a place to get corn every once in awhile. If that idea fades away, itll probably be K04's. But I really wanna hit 500-550.
    Dec 03 2009
    PNW, Washington
    Quote Originally Posted by Bordom View Post
    No fun with F21's?
    I actually haven't had a chance to run a F21 car. F4H yes, but doesn't really count as he was on a stg3 minus file. F21's are so similarly size to k04's anyways I would argue they are direct substitutes. Then it becomes a personal choice of do you want to save a couple hundred on a copy, or buy the genuine product.
    Quote Originally Posted by MarlinFoundNemo View Post
    Unfortunately that's the downside of living in WA. Absolutely garbage west coast gas. To put down any halfway decent numbers meth injection is required, or run e85 and just the task of obtaining e85 on the western side of the state is a feat in itself.
    I look at it like this; k24 cars on stock block and pump gas some times put down attractive peak HP numbers. People are wowed and everyone goes crazy thinking they are the hottest commodity. The reality is different. You lose spool and the boost onset is typically delayed to save the motor. So if you have a halfway decent k04 car and a k24 car, both stock block. The k04 car wins time and time again. It spools faster, hits harder, and transient boost recovers much quicker in between gearshifts much quicker.
    These are just things I've observed over the years first hand. I'm sure some others have completely different opinions from me, but I let real world results form my conclusions, not hypothetical internet bench racing, or inflated dyno numbers.
    Jun 08 2014
    I will definitely run meth no doubt. I'll look more into other turbo setups down the road. And yes, our gas is trash :(
    May 16 2008
    South Texas
    Glad it worked for someone I've had installed three and had all three slip on stage II power. It's a POS as far as I'm concerned.
    Jun 08 2014
    Quote Originally Posted by Scotty@Advanced View Post
    Interesting.. Would spending a little extra for a RS4 Clutch/PP with some other flywheel be better?
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    I wouldnt go valeo personally. I bought my s4 with a stage 1 asp tune and a valeo clutch qith 10kmiles on it from a buddy. As soon as i installed the milltek turbo back on the car the clutch started slipping. The shop who replaced clutch for me called me mid clutch swap asking if im sure i want to replace what looks like a brand new clutch that is in the car already lol
    Aug 04 2014
    Gloucester MA USA
    I would say yes. Go with a dmfw from rock auto for 350. Unless u want a lightweight in there. (I chose not to go lwfw route)
    Jun 08 2014
    Quote Originally Posted by f4m0u5 View Post
    Great idea, I didn't even think about them! Looks about 307 including shipping! Comes with hardware too I expect? I don't need a lightweight right now, so can't really justify spending more for one.
    Aug 04 2014
    Gloucester MA USA
    I thought it was close to 300 but i said 350 to be saglfe lol, and. I dont remember what came woth it to be honest, but i know i bought the oem fw bolts on ecstunings website to be safe on lemgth and what not
    Jun 08 2014
    Are these two the same..? Same MFG# but ones drastically cheap than the other. Look identical as well.
    https://www.europaparts.com/clutch-k...78198123g.html
    http://www.uspmotorsports.com/Drivet...4-and-RS4.html
    Edit: part numbers are NOT the same..oops
    Jun 08 2014
    Okay, I shall buy the bolts from them then to be safe.
    Jun 08 2014
    Does the SAI system NEED to be blocked off/deleted?
    Nov 03 2011
    All Over!
    TTV steel single-mass is the best bang for your buck. It's lighter than the stock dual-mass item, yet still has enough mass to absorb the rattle and chatter that is present in every transmission, but are usually damped by flywheel and crank pulley weight.
    I've got one, and love it.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Delete it you don't need it with the 6 speed swap.
    Jun 08 2014
    Quote Originally Posted by xalents23 View Post
    It's right behind the manifold, drivers side? How do I delete it? Been searching for 30 minutes cant find any good info. I am aware of the SAI block off kit by 034 too, is that necessary?
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    I just made my own block off plates from aluminum. Easy peasy. Still have cel for sai though. You have to block off both heads
    2002 Pearl/onyx S4 Avant
    Oct 26 2011
    CA
    Here's a link to the SAI deletion. If you are using the tiptronic heads, then yes you will need block off plates.
    http://audisrs.com/archive/secondary...__t_24440.html
    Jun 08 2014
    Thanks. Do I need two sets of those plates or one?
    Dec 10 2013
    For an extra $150 you can have a TTV flywheel with B7 RS4 clutch provisions. The repset is only $180ish
    IG: 24_et
    Sold:
    RIP:
    Jun 08 2014
    I see two options on their site.. One is to use the B7 RS4 clutch and one is not. Do I REALLY need to run a b7 rs4 clutch? A LUK OEM B5 RS4 should be fine for my needs.
    And how much is the flywheel..? An inquiry will take too long if someone has the answer here lol
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    its around 450 i think... been awhile since i paid for mine
    Dec 10 2013
    345£ for the B7 Mod, and 318£ for the standard shipped to Canada. So about $450ish USD. The B7 RS4 one is more robust and much more affordable than the B5 RS4 clutch. The SAC is also metal instead of plastic
    IG: 24_et
    Sold:
    RIP:
    Jun 08 2014
    Right now with a DMFW OEM and a LUK RS4 clutch kit, I'm looking at about $800. What'd be the total for a TTV and B7 RS4 clutch kit?
    Oct 26 2011
    CA
    Just one set.
    Jun 08 2014
    Just one set.
    Thank you!
    Dec 10 2013
    $630 approx.
    IG: 24_et
    Sold:
    RIP:
    Jun 08 2014
    $630 approx.
    Oh wow thats a much better deal. So I'd order the TTV "rs4" flywheel and then where do I get this hella cheap b7 rs4 clutch/pp kit haha
    Dec 10 2013
    You get it from Rockauto. I got mine under 2008 RS4. It's a Luk repset
    IG: 24_et
    Sold:
    RIP:
    Jun 08 2014
    Thank you!! This flywheel correct? http://ttvracing.com/product/audi-s4...ufacturer=audi
    Next question, with the SAI delete, will one of these be a good idea as well to prevent CEL's?
    http://www.performancebyie.com/integ...rectangle-plug
    Jun 08 2014
    About 2 weeks out from starting this. About to order parts but before I do I want to know if anyone sees something I'm missing.
    Already have:
    Rebuilt 01E, Rear diff, linkage, shifter box, trans mounts, driveshaft, brake booster, pedal assembly, 6mt harness, trans-motor bolts.
    Need to buy:
    Passenger/Driver Front CV Axles - Autozone (blah blah OEM is better. I'm not stage 3 theyll be fine)
    Tip-6mt Harness (reverse/neutral safety switch)/starter switch/brake+clutch switch - Advanced Automotion
    Flywheel/Clutch Install bolts - ECS Tuning
    OEM Engine Mounts - ECS Tuning
    SAI Blockoff Plates - 034 Motorsport
    SAI/EVAP Delete Resistor - Integrated Engineering
    LUK Repset B7 RS4 Clutch Kit - Rock Auto
    TTV LWFW for B7 RS4 Clutch - TTV Racing
    Stainless Steel Clutch Line (keeping stock slave) - USP Motorsport
    All gaskets/TB done at 144k (160k now), coolant was replaced so I'll reuse that as well. Oil was just changed, not touching that.
    What brake fluid do I use?
