Results 1 to 4 of 4
    Active Member One Ring 0face's Avatar
    Mar 21 2013
    Evanston, IL
    What did I just break?
    Snapped this:
    It was attached to this plug:
    I'm going to replace the dried out vacuum lines.
    B6 A4 3.0
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    doesn't that broken hose go to the vacuum canister?
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Mar 21 2013
    Evanston, IL
    It Connects underneath that plug on the right in the second picture. Underneath where the blue hose goes. I can't find what part it is to replace it.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    That looks like the vacuum solenoid valve that controls the intake changeover valve (the part that rotates inside the intake when the engine reaches ~4200 rpm).
    Try this P/N: 079906283C
    Good vacuum line info here: DIY-B6-A4-3-0-Complete-Vacuum-Line-replacement
