Results 1 to 26 of 26
    Feb 18 2013
    Silicon Valley, CA
    Can't find the boost leak. Am I insane?
    Boosted to around 20ish PSI, and car shut down. Dead.
    Got it home, charged the battery (a separate issue apparently), and the car runs very rough and has terrible throttle response.
    I unplugged the MAF, and the car runs fine, normal throttle response.
    Plugged in my leak tester, and i can't find any escaping air.
    Any ideas on where to check?
    Could the MAF have crapped out all at once?
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    check throttle body boot first, then make sure you smoke test/pressure test with enough PSI if you're still not finding a leak.
    Replace that MAF, they need replacing every once in a while anyways
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by TheDarkness View Post
    TBB doesn't give off any hissing noise, and doesn't put out any air that I can feel with my hand when testing.
    I started with 5PSI, worked my way up to 15.
    It seems odd that it would just go out completely in one second.
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    Really dont think its a boost leak, it has happened to me and you can still drive it, it wont die on you that sudden, i thinks you're more into ICM or fuel related (fuel pump)
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Quote Originally Posted by 2000s4_m View Post
    When my icm went out it gave me the same symptoms as when I tore my tbb. I also pressure tested when my tbb ripped, and never found it until I actually removed the tbb. No faults in the system?
    2002 Pearl/onyx S4 Avant
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by 88ninety9 View Post
    No Vag-Com codes.
    Car will run forever with the MAF unplugged, so I don't think it's fueling.
    If it were ICM, I would expect the same issues to occur with the MAF unplugged as plugged in, right?
    Oct 09 2011
    Farmingdale, NY
    Do you get super loud turbo whistle sounds when you're driving with the MAF unplugged? Check under the car the intercooler hoses that come right off the turbo.
    B5S4
    IG: Dalers08
    Build Thread
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    If it runs fine with the maf unplugged you have un-metered air post maf, pre manifold. You have a big leak. Find it
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Feb 23 2010
    Emmaus Pa
    It runs fine with the maf unplugged. It's a leak.
    B9 S4- EPL/AWE
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Agreed. Squeeze and wiggle your hoses while leak testing and use soapy water for fucks sake
    Sep 05 2012
    Mcallen, tx
    Quote Originally Posted by Tumbler510 View Post
    No Vag-Com codes.
    Do you have an extra maf? To try and see if its the actual sensor that went wrong
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by CELison View Post
    I jsut unloaded a few tanks of my compressor trying to find it. Not a hiss or any air movement I could detect. Any way it could be in the spider hose or one of the mechanical parts in that line?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Does your gauge show the system holding pressure once the air source is turned off?
    Also, does it feel like you're getting boost with the MAF unplugged, or is the car super slow?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by LINDW4LL View Post
    I don't pressurize the system, so there's no telling.
    I haven't driven it with the MAF unplugged yet. It has been on jacks since it was towed back.
    Dec 10 2011
    CLT | MKE
    How do you test then?
    -Hayden
    Feb 18 2013
    Silicon Valley, CA
    Flow air into where the air filter usually is with the oil fill cap removed and the pancake valve port blocked.
    Dec 10 2011
    CLT | MKE
    OK, that's what I meant. It should look like this as far as holding pressure...
    -Hayden
    Feb 18 2013
    Silicon Valley, CA
    Oh yeah, no gauge on my leak tester
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    reading these comments amuses me CELusion they have no idea what they are doing
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    please if you have no idea how engine management system works don't reply with your fixes . your just leading them in the wrong direction
    a maf calculates airflow thats it .
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by AudiTechS4 View Post
    Yup.
    Any ideas I can try?
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    I've had a broken intercooler where the whole top.broke off and you couldn't even hear the leak because it was so big. You need to see if it's holding pressure
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    As said before pressure test with some kind of gauge and check valve to see how it holds pressure
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Maybe you bent some valves. Maybe r fuel pump died
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by DxC View Post
    Don't think so.
    I have compression because the car is running.
    And my fuel pump is working because the car is running.
    Feb 18 2013
    Silicon Valley, CA
    If it helps any, the car runs fine when I have the clutch in.
    The second I let eh clutch out (even in neutral),the car gets the rough idle, and stalls.
