Results 1 to 16 of 16
    Established Member Two Rings pgiuliano98's Avatar
    Jun 22 2015
    Livonia, New York
    "Supercharger" sound coming from turbo... Blown turbo?
    2 days ago I started hearing a
    supercharger-ish like noise when I was under boost. My gauge still shows that I'm making the same 11psi at WOT but I feel like I've lost power and it doesn't really have much umph anymore.
    I've read a lot about it and people say to look for holes in hoses but quite frankly I have no idea where to start.
    Not sure if this matters but 5 days ago I put on a 3" turbo back exhaust with a test pipe.
    Veteran Member Four Rings rockbeau25's Avatar
    Dec 06 2014
    B5 A4 Avant, 4L Q7 TDI, Van Diemen RF99
    WI
    If this is the so called dentist drill sound, then yes, your turbos on its way out,
    B5 A4 Avant
    4L Q7 TDI
    Van Diemen RF99
    Jun 22 2015
    Livonia, New York
    Just went out for a drive. Boost gauge shows 9psi under WOT and sounds normal up until 3-4psi.
    Dec 10 2013
    Borden, Ontario, Canada
    Turbo is almost dead
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jun 22 2015
    Livonia, New York
    Quote Originally Posted by Bordom View Post
    Would that have anything to do with the larger exhaust I just put on a few days before I started hearing this noise?
    Dec 10 2013
    Quote Originally Posted by pgiuliano98 View Post
    Not likely. If anything, the turbo would have an easier time spooling. At least it's giving you some warning and not just blowing half the CHRA down the exhaust along with most of your oil.
    IG: 24_et
    Sold:
    RIP:
    Jun 22 2015
    Livonia, New York
    Would a Borg Warner ko3 from a 2000 A6 2.7t fit on my car? A guy near me is selling them for a decent price.
    Dec 10 2013
    Probably not without some modification
    IG: 24_et
    Sold:
    RIP:
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    You can get a cheap K03 from CXRacing.com. Also try a junkyard, just check shaft play before pulling it.
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    Established Member Two Rings SacSantorin's Avatar
    Aug 18 2015
    Almost Canada, WA
    Im noticing what sounds like turbo flutter in that video. You should not have that if you have a diverter valve. Turbo flutter is the compressed air forcing its way back through the turbo in order to vent after you've let off the throttle. You have a DV problem which is probably what led to your turbo taking a shit on you. Check you DV and the vacuum line that runs to under the manifold!!!
    2000 Audi A4 1.8T | Santorin Blue | Frankenturbo F21L Mixed Flow | Motoza 550cc Tune | Custom 2.5'' Exhaust w/ Milltek Downpipe | 3'' MAF Housing | 3" Ebay Testpipe | CX Racing FMIC | B6 5 Spoke Wheels | ECS Boost Guage | OEM RS4 Grill
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    1999 A4 FWD AEB 1.8T ~ Atlas
    Jun 22 2015
    Livonia, New York
    Quote Originally Posted by SacSantorin View Post
    Thanks for the input, I had no idea! I'll check today and report back.
    Jun 22 2015
    Livonia, New York
    Still haven't decided on what turbo to get.. First I went from k04 build to just a stock k03 then back to k04 build and now I'm thinking about FrankenTurbo... I'm gonna need time to get some money together but how much time do you guys think my turbo has, given that video^, before it actually "blows up"?
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    What tune are you running? Stock is 8-9. Most tunes are 17-21. You may also have a large boost leak if you've only been seeing 11. I'm not able to watch the video so I can't comment there.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Jun 22 2015
    Livonia, New York
    Eurodyne AEB Stage 1 tune, usually peaked at 13-14psi and would hold at 11psi until around 5k.
    I emailed them to get the specific specs and they said it should peak at 14-17psi. I've never been above 14.
    Jun 22 2015
    Livonia, New York
    This seems like a great deal... Right?
    Bigger injectors, FPR, a BW K04, and PC16 file for under $700?? I thought the k04s went for over $700 alone!
    http://store.excelerateperformance.c...xJEaAmk18P8HAQ
