Hello all,
I hear loud exhaust noise plus whole car vibrates when I drive between 20-30mph. I hear lapping sound in the catalytic converter unit when idling cold start and driving too. The engine light comes on sometimes. Taking reading seem the mass flow reading is too high even at warm up temperatures of engine.
Can the faulty catalytic throw mass flow readings off the range? Looking at MVBs, I see the 02 sensor control value seem high too. Any hints and tips would be appreciated.
Thursday,05,May,2016,15:20:40:46890
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: License Plate: TTAUDI
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Control Module Part Number: 8N0 906 018 AN
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 06710
Work Shop Code: WSC 65728
Additional Info: TRUWT28N321018606 AUZ5Z0A9310089
VCID: 7DFA30ED774644D615-5102
2 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P0135 - 35-10 - Malfunction - Intermittent
Readiness: 0010 1101
Address 01: Engine (8N0 906 018 AN)
15:21:22 Group 002
720 /min Engine RPM
35.3 % Engine Load
2.46 ms Ave. Inj. Period
5.14 g/s Air Mass Flow
15:21:27 Group 002
760 /min Engine RPM
34.6 % Engine Load
5.11 g/s Air Mass Flow
15:21:33 Group 003
720 /min Engine RPM
3.1 % Throttle Opening
6.8 °ATDC Ign. Timing
15:22:31 Group 003
720 /min Engine RPM
5.17 g/s Air Mass Flow
8.3 °ATDC Ign. Timing
15:22:41 Group 004
760 /min Engine RPM
14.140 V System Voltage
87.0°C Coolant Temp.
21.0°C Intake Air Temp
15:22:46 Group 005
760 /min Engine RPM
33.8 % Engine Load
0.0 km/h Vehicle Speed
Idle
15:22:57 Group 006
720 /min Engine RPM
33.8 % Engine Load
-4.7 % Lambda
15:23:25 Group 030: Heated O2 Sensor Status
111 HO2S#1
110 HO2S#2
Bin. Bits
Bin. Bits
15:23:29 Group 031
0.835 V O2S1 Voltage
0.180 V O2S2 Voltage
Bin. Bits
Bin. Bits
15:23:34 Group 032: O2S Adaptation
-6.9 % Idle Value
-0.8 % Part Throttle Value
Bin. Bits
Bin. Bits
15:23:44 Group 033: Cat-Forward
-10.2 % Control Value
0.415 V O2S1 Voltage
Bin. Bits
Bin. Bits
