Results 1 to 7 of 7
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Evap won't set. Cannot inspect vehicle.
    After engine pull. About 130 miles it's time to inspect the vehicle.
    Here's some pics.
    The evap + secondary air system won't set.
    Sent from my SM-G900T using Audizine mobile app
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    Aug 09 2012
    Bay Area
    Quote Originally Posted by xhackerekx View Post
    VCDS lets you set the readiness from the computer itself with out any driving. You should try that first.
    Aug 30 2015
    Derry NH
    It is the same ecu. We just unplugged it. . During engine pull..
    Aug 30 2015
    Derry NH
    I thought the immobilizer was for ignition? And starting the vehicle.
    How hard is this to do myself? If I decide to purchase Ross tech.
    I should be able to take it to a shop that has vagcom? Or audi?
    Thanks for the help!
    Feb 18 2014
    Arizona
    the thing about the immobilizer is just his sig... I don't know what he was trying to say with that photo but as Kambesana explained, it can be done with vcds. It was a pain in the ass for me when I did it. As long as there are no faults with SAI you should be able to get it to pass just by doing more driving, I know sometimes it takes a lot of miles to get everything t show passed just by driving. Would your obd scanner tell you if there was a code for SAI?
    Aug 09 2012
    Bay Area
    Quote Originally Posted by bmwpower603 View Post
    For me I just followed the instructions on screen. Most of it required me to step on brakes and floor accelerator. From there the computer limited the RPM to where it wanted (1800-2300) and I just did that. NO driving required just sitting, reving, and reading. Sometimes when the test didn't start I pressed the button on the top to get it started.
