EDIT: Just to update, it turned out that my Forge DV failed. Not exactly sure how, but I am taking it apart to investigate. Had a spare revision C dv laying around. put that in and was good to go.
So i just did a boost leak test with the pvc pipe with fitting and compressor trick. My car is underboosting obviously.
The sound I heard is very strange, it sounds like air is bubbling around in the oil, down in the pan maybe? Only connection to the oil system I can think of is the pcv system, I have a 034 catch can. Is the return line from that allowing air in? Wtf?
Sent from my SM-N900V using Tapatalk
