So I am wanting this Enkei wheel, and was told the offset was 45mm. The tire rack specialist told me I could not run that offset because it is too high and it will hit the break caliper.
From what I've read, you can go from a 35mm-45mm offset on the B7 S4 so I'm wanting any opinions on wether I should chose another wheel or what I should do...
Thank you
http://www.tirerack.com/wheels/Wheel...Standard+Model
