Results 1 to 16 of 16
    Established Member Two Rings Chris250's Avatar
    Nov 22 2013
    Baltimore
    Angry Crack in door arm rest
    the car is only 5 years old!!
    Is there any hope here? Is there a replacement for this other than buying a whole new door panel? Fixable? HALP!
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Active Member One Ring zchristopher10's Avatar
    May 04 2015
    austin Tx
    I have the same problem on the exact same spot!!
    Sent from my SM-N920T using Tapatalk
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Try a leather repair kit? I would look for the part on eBay (or a junkyard) before spending $254 for the ECS replacement part.
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    Seems insignificant enough to spend 250 for a new one. Look at some total A4s being parted out first or give it a shot with a repair kit. Other then that If it were me I would live with it.
    2010 Audi A4
    6 Speed Manual
    Premium Plus
    30% Tint all round
    RS5 Honeycomb Grill
    Valentine One Radar
    Weather tech laser fit mats
    110,XXX Miles
    Oct 23 2014
    Buffalo, NY
    or LKQ.
    °2011 A4 | 6MT
    Feb 24 2013
    CA
    For 260, you can probably get them all rewrapped with real lether instead
    Mar 26 2014
    I got the same problem, same spot.
    Veteran Member Three Rings Spm58's Avatar
    Nov 03 2014
    Long beach, ny
    i have the same exact thing. Happened like 2 months ago. Let's demand a recall!
    2015 sepang blue s4• Ecs luft-technik carbon Intake
    Active Member Two Rings PkB8's Avatar
    Sep 07 2015
    Ha. I got the same thing
    Established Member Two Rings alk's Avatar
    Jul 23 2011
    Denver
    I have a similar issue. It's very unsightly, even with a dirty car!
    I'm looking at DavidB8's excellent write-up on ambient door pocket lighting, but naturally he doesn't show how to remove the armrest piece from the door panel.
    http://www.audienthusiasts.com/Proje...rLighting.html
    Does anyone have any pictures or a description of how the armrest is attached to the door panel?
    -alk
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Quote Originally Posted by alk View Post
    I haven't done it, but I am pretty sure you have to remove the entire door panel to gain access to the screws or fasteners holding the arm rest on.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Established Member Two Rings a4efforts's Avatar
    May 15 2017
    '09 A4 B8, '17 PORSCHE MACAN & '08 BMW X5
    Atlanta, GA
    Quote Originally Posted by choppstixxx View Post
    Correct. Mine is 9 years old, but doesn't look like those above. I only looked into this project, because I wanted to swap in the RS4 leather ones. There are leather covers on ebay now though.
    https://www.ebay.com/i/231396265418?chn=ps
    some have contrast stitching options.
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Any shop that does automotive interior work will be able to repair that quite well, not sure how much they would charge you, but it is definitely repairable and will be invisible after the repair.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Jul 23 2011
    Denver
    That’s interesting. I wonder how well they fit over the existing armrest...
    Jul 23 2011
    Denver
    Yeah? Do you have personal experience with that? I’d hate to put in 1/4 to 1/2 the cost by repairing them then being dissatisfied with the results and end up paying for replacements anyway...
