Results 1 to 12 of 12
    Dec 19 2011
    Colorado Springs
    Strange High idle
    Driving home from work today, I put the car in neutral coasting to look at my tach and realize I was idling at 2k rpm...tested it again when I got home and I have a mysterious throttle hang and still not a normal idle.
    Car boosts fine, could be a vacuum leak..but if so it must've just happened on the drive home.
    if driving, and have the car in gear, clutch in.. it idles around 850-900 where it should...Im confused.
    Anybody? T-Body alignment time? (again) Bad MAF? Just a really weird vacuum leak I need to track down?
    Videos:
    https://youtu.be/go2Dfl56lsY
    https://youtu.be/6d4ZwJLQj1I
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Aug 27 2013
    Philly
    Quote Originally Posted by B6A4Dave View Post
    Videos:
    Ahh. Since it doesnt do it when moving with the clutch in, I bet its related to the clutch switch. If you're moving and you and clutch, the throttle body operates differently than it does when your sitting still reving the engine. Old Guy explained it somewhere, but I can't find that post.
    Dec 19 2011
    Colorado Springs
    Quote Originally Posted by SJorge3442 View Post
    Well thats the strange thing...it stopped doing it dependent of the clutch position..
    On the parked video I put it in gear and blipped it and the idle didnt stay all funky like it did while driving..
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The upper clutch pedal switch causes the throttle to hang if the clutch pedal is all the way up and the car is moving. Once you stop moving the throttle no longer hangs in relation to the pedal position. That's why you experienced it in neutral while driving but not when parked.
    The purpose of the throttle hang is to make your transition from on/off throttle a lot smoother when driving the car.
    Dec 19 2011
    Colorado Springs
    So....whats causing this? its never done it before.. and ive owned this thing almost 6 years..
    Dec 28 2006
    Western Maryland
    Don't know what to tell you other than it is now acting normal.
    Dec 19 2011
    Colorado Springs
    CEL Popped on this time...
    6 ECU fault codes stored.
    P0300
    Random/Multiple Cylinder Misfire Detected 16684
    P0301
    Cyl.1 Misfire Detected 16685
    P0303
    Cyl.3 Misfire Detected 16687
    P0304
    Cyl.4 Misfire Detected 16688
    P1297
    Connection turbocharger - throttle valve pressure hose 17705
    P0507
    Idle Control System Higher than Expected 16891
    P1297? aka: smoked SJP?
    Dec 19 2011
    Colorado Springs
    Cleared them aaaaaand...
    https://youtu.be/1QKkQcIAzSc
    Dec 19 2011
    Colorado Springs
    I've come to the determination that Its probably time to replace my OE 2003 SJP..
    My part number is, 058 133 753 B, is the 058 133 753 D a revision update?
    And If I do it, I'll probably replace the connecting hose, 058 133 784 P.
    I did notice when I boost leak tested the car that my SJP had a small leak..but perhaps that is part of my issue.
    This seems like a really good deal if it's all legit OEM >>> Clicky Click (trademark OldGuy) <<<
    Dec 28 2006
    Western Maryland
    "D" is just an updated version. and yes that looks like a terrific deal!
    Dec 28 2006
    Western Maryland
    I doubt that code is being caused by the SJP unless it's totally separated. A small leak typically won't dump enough pressure to give you a P1297.
    Dec 19 2011
    Colorado Springs
    Come to notice it now the brand is "OEM" and origin is China, just shipping out of the US..I think they're the same ones that are it the " look what showed up from china " post
    I can tell ya this, after I cleared the codes, I've probably drove 300 miles and hasnt come back, and my idle has returned to normal.
    note, I have a big hesitation and stutter/stumble one cold start, and for the first time today Outside of using E85 in the Colorado winter a Flashing CEL ( Severe misfire ) idling when cold..
    So, thinking I may need an SJP.
    That, and my dying 218.5k engine is losing compression..part of why my 2.0L stroker block is getting built.
