Page 1 of 3 123 LastLast
Results 1 to 40 of 91
    Senior Member Three Rings mik34's Avatar
    Feb 04 2010
    Manitowoc, WI
    TD1 flag despite flashing to stock
    I developed a coolant leak to the turbos. There is a TSB for it (2036167/1). I flashed back to stock prior to taking the car in but they still found the tune and it was flagged TD1. I'm out of my warranty (56K miles) but given there was a TSB I flashed to stock first thinking Audi might still cover the repair. To my surprise, they agreed to pay 90% of the repair (without any haggling by me) despite being out of warranty AND getting the TD1 flag. Not sure the tune had anything to do with the leak given there was a TSB, but I thought they'd balk at covering it.
    So there you go, they can definitely find a tune despite flashing back to stock. Doesn't bother me since I'm out of warranty anyway, but thought it might clear up some confusion. Pleasantly surprised Audi is covering most of the cost.
    Sold: 2013 : Ice Silver, Carbon inlays, APR tuned, 21x10 HRE S101, AWE exhaust, Carbon fiber mirrors from RS6, Drilled rotors, H&R lowering module, Escort 9500ci, Ceramic brake pads, Deval carbon fiber rear diffuser, Xpel Ultimate, Opticoat
    Sold: 2009
    Whoever said money can't buy happiness...doesn't own a (tuned) S6.
    Veteran Member Four Rings SharkNardo's Avatar
    Mar 16 2007
    Richmond, VA
    Interesting...I wonder if they can find all tunes or just certain tunes like the APR tune you have?
    Other Cars
    2018 Golf R
    2019 Golf Alltrack SEL
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    Quote Originally Posted by mik34 View Post
    The one other factor could have been if the actual flash counter was not reset to 0. They may not have been able to detect the actual tune but they could see that the ECU had been flashed. As you said though out of warranty and Audi is covering 90% not a bad outcome. I would have thought that with a TSB they would cover 100% of cost regardless of warranty status. Did they say that they wont cover all because of TD1?
    B6 S4 Cab - Sold
    B7 S4 - Sold, (sadly sold, this was my favorite)
    C6 A6 3.0T - Sold
    B8 S4 - Sold
    2015 SQ5 - Sold
    C7 A6 3.0T - Sold
    2016 SQ5 - Sold
    C7 S6 - Sold
    B9 A5 Sportback - Sold
    C7.5 S6 - Current
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    Nice they're covering 90% but maybe because there is a TSB, and can't prove it was your tune, they did that?
    Mar 27 2016
    St. Louis
    This is a serious issue for anyone who is tuned. Just curious, did you admit the car was tuned?
    Mar 29 2014
    Hampshire, UK
    There is an interesting discussion ongoing on this sister group that may be worth reading.
    Its UK focused (and relates to an S3) but its relevant.
    http://www.audi-sport.net/xf/threads...of-woe.273664/
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Car manufacturers kill me with this TSB bullshit. If you know your product has a flaw, fix it at no cost to your customers under some sort of voluntary or rolling recall! OP, the fact that there is a TSB would have made it less likely for them to prevail in litigation on the tune being the cause of the problem. Of course, the average citizen would probably just suck up the cost rather than deal with litigation.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    I don't know why everyone doesn't understand that Audi can see any car thats flashed!!!! Even back to stock??? Why is this so hard for people to comprehend!! Unless you have a 100% stock ECU and swapped that in before going to the dealer and the dealer runs a spec/actual as required for almost any repair at this point it will be flagged..... And don't get mad at Audi (not op) if you wann play, you've gotta pay!!!!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jul 21 2004
    South Florida
    Quote Originally Posted by quattro16 View Post
    I wish it were that cut and dry. The thing is that there have been literally tens of thousands of people who have flashed back to stock and not been flagged on the spec/actual when the proper OEM file version was loaded onto the ECU.
    There are literally only a handful of people who report being TD1 flagged after flashing back to stock and many times when the tuner looks into it there seems to be an explanation such as the incorrect OEM file revision "ie, 0002 instead of 0005" was installed. In some cases, it turns out the dealership manually flagged it (and many won't fess up to doing that).
    I do agree that Audi could change their methods for detection anytime so no one should assume they are safe by flashing back to stock. Audi could implement event recording (ie, record when the car exceeded certain load conditions or rpm thresholds or past OEM max speed limiter etc) and store them in a different location of the ECU and they could catch flashed people left and right but as of now they are just running spec/actual on the files according to them. I liked doing the piggy back to be extra cautious but in fairness, I did a flash too and it was never flagged either.
    I do agree with you that one shouldnt be completely in shock if they get a TD1 even after flashing back to stock but it does seem to work over 99% of the time...until Audi decides to change their methods...and then the tuners change their countermeasures...and then.... :)
    Mike
    2018 Audi S5
    Gone-
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Happened to me also. Flashed to stock and got flagged. What surprised me was that APR checked the burn logs and everything was set back exactly to how it was before tuning. What surprised me more was the flag disappearing pretty much by that evening and could never be found again on running the VIN. Here is my take on it- there is no guarantee of the flash not getting detected.. so we can try to play it by flashing to stock but still be mentally prepared to get flagged.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Feb 05 2007
    Long Island, NY
    Audi has changed procedure recently and for the most part in the past 90% of the tech's were not running spec/actual for the majority of the cars coming in. Now that the Audi procedure has changed and spec/actual needs to be run on almost any complaint besides a service you are seeing a ton of TD1s... And it's only going to get worse. Not to mention you have tech's (myself included) who are sick and tired of fixing cars under warranty for something that simply should not be covered because of certain mods. And don't call me the bad guy as I've almost always done the right thing for the majority of the customers and have no problem banging Audi when warranted.....
    Mar 11 2014
    Dallas/TX
    Well we know quite in detail about the change in procedures. There are certain dealerships that wont even take the car in for regular maintenance now if you ask them to not perform a spec/actual. They tell us upfront that any car coming for any reason will be connected to the factory systems. Also, coming to fixing cars under warranty - the customer and the dealership should be reasonable in their approach. Audi is known for failing motor mounts so blaming that on a tune ( as happened in my case ) would be unfair. However if I redline my car straight for 20 mins and blow the turbo/transmission and expect Audi to cover it, that would be unfair again.
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    FWIW my friend who runs an APR dealer told me there is no way to reset the flash counter to 0, so even if you flash it back to stock you will still have a 1 on the counter.
    2012 Q5 2.0T
    2010 A6 3.0T
    2004 A4 Avant 6spd 1.8T (SOLD)
    1998 A4 quattro (SOLD AND MISSED)
    2006 Suzuki sv650
    Veteran Member Three Rings goreckless's Avatar
    Aug 17 2009
    Stamford, CT
    Oh, you engineer ECU's at Audi?
    You see, in software engineering we call this black box testing. You throw different cases and variables at it seeing what happens because you do not understand the inner workings of it. Until we get an actual Audi employed developer to give us their story, you have no idea how any of this works.
    2014 Audi A4 | 6MT | Brilliant Black | S-Line
    APR | AWE | Eurocode | CTS
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    Quote Originally Posted by goreckless View Post
    You don't have to be employed by Audi to understand they have the potential to see anything. What's to say an ECM + MMI update doesn't start sending your metadata back to Audi via Audi Connect? I don't see that happening today, but Tesla has already shown that capability in their cars.
    If you develop software, you should know anything is possible.
    Apr 08 2013
    What if you are the second or third owner? Think it would be a plausible excuse to say it could have been the previous owner? Just wondering everyone's opinion
    MoTeC m1 powered Seadoo RXTX
    c7 s6 [email protected] gone
    997.2 TT-S [email protected] COBB/BBi
    Mar 18 2011
    Denver
    If you buy a car CPO and its flagged TD1, you clearly have a case. Otherwise, I think Audi has the upper hand in that argument.
    Aug 17 2009
    Stamford, CT
    Quote Originally Posted by jfeger View Post
    This isn't even close to what I said. You use the word "potential" but we don't work on potentiality, we work on facts. Hell, Audi's ECU has potential to be recording all your conversations in the car.
    I'll say it again, if you didn't develop it or have documentation on the development, you don't know how it works.
    Feb 05 2007
    Long Island, NY
    LOL typical kid post. Not even sure what you're implying but I'm just teling you how it is. You flash your car and from this point forward you go to the dealer and it will be flagged TD1. There's really not much more to discuss. You can sit at your desk and theorize all you want the internal workings of an Audi ECU but I'm sure just when you figure it out, it was changed 6 months beforehand.....lol
    PS. Yes I know Audi engineers....
    Aug 17 2009
    Stamford, CT
    You don't know Audi software engineers.
    Typical computer illiterate.
    Jan 27 2016
    Denver
    Vol 2.0? :)
    Jan 27 2016
    Denver
    Vol 2.0? :)
    BTW. Since he is in the tech network for Audi...it's plausible he does know them.
    Oct 27 2015
    Latvia
    I have ECU tune and I have always told the dealer that I have it and don't make any software updates, so far so good, no problems with warranty.
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    That's exactly what tuners have done to their best ability to reverse ECU back to stock by trying to produce the same outputs and parameters because they don't know everything inside exactly but what makes you think that Audi can't have a way or produce a tool to analyze what in their own blackbox?
    And no, you don't have to be Audi ECU Engineer to figure out that they have the ability to do so.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Jul 21 2004
    South Florida
    Quote Originally Posted by ecpChris View Post
    Audi has reversed the TD1 process for customers how have returned their cars to stock. They will not guarantee it and if there was already a claim pending, this does not guarantee that claim will get approved but there is a procedure in place to have a TD1 removed. There are some threads on TD1 that have this information.
    Quote Originally Posted by seanentrust View Post
    APR has been resetting the flash counters for several years now. They have gone the extra step to set the flash counters, flash dates, and WSC back to whatever value your own ECU was at prior to having the performance flash. This could vary by vehicle as it should. It will be the right flash counter info for your car. It has not been confirmed that AofA looks at flash counter data at this point in time though as it does not appear to be read when doing a spec vs actual.
    Again, this just isnt the case. There are literally thousands of cars that have had GFF run on them and been hooked up to the mothership and not been TD1. You will find a total of about 10 people who have been flagged after having the stock file flashed on all the forums. All the rest including myself havent been. So is flashing back to stock a 100% guarantee you wont be flagged? No, its not. It can still happen. In most cases it doesnt though (over 99% it seems).
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Well this conversation bums be out....
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by Djpeaksd View Post
    I already went ahead with the tune and I will be due for service next month. I will be flashing back to stock but will also communicate that I have tune. Usually my dealership is cool with that so we will see what's gonna happen.
    Other: 2017 BMW X1
    May 08 2004
    NoVA
    I doubt they care who tuned it - just the fact that it has been tuned beyond the factory parameters.
    Feb 05 2007
    Long Island, NY
    Quote Originally Posted by bhvrdr View Post
    Mike
    Just so you know GFF is not the same as spec/actual nor does it run automatically. Yes I can run every car that comes through with GFF and send the log in and fix the car and not get flagged.
    Spec/actual test plan has to be manually selected and ran. More dealers are making it mandatory so claims don't get kicked. And not only that but with every Audi tester update that comes out it's being implemented into most test plans first so we have no choice.....
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Audi ECU engineers! You guys are saying as if they made their own ecu/developed their own software.
    Dec 20 2006
    CAN
    As an aside here, what are the issues, if any with tuning the ECU on a leased vehicle? If you're handing it back to them at the end, it's their problem, not yours. This assumes no major repairs needed prior to end of lease.
    tia
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and very inexpensive compared to any other payment processor.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by aysix View Post
    They definitely don't make their own hardware but as for software, at least the lead engineer must be Audi's employee. As much people like to think that now a day the corporations outsource this kind of job to oversea and nothing is made in house anymore, the statements on the back of iPhone that "Designed In Cupertino" is actually true for both hardware and software.
    Other: 2017 BMW X1
    May 29 2014
    United States
    Quote Originally Posted by VeryBadman View Post
    I'll be asking you more about this tonight!
    2014 Q5 3.0T Lava Grey S-Line Sport Package 034 Stage II KW HAS Roc-Euro Magna Flow 034 Rear Sway
    Jul 21 2004
    South Florida
    Audi's current dealership level diagnostic equipment allows for automatic detection of unauthorized ECM tuning on many current vehicle models. Every new model year will bring more vehicles which will automatically be detected; this detection runs automatically in the background of the normal diagnostic process, and will be completely transparent to the technician working on the vehicle.
    http://www.audizine.com/forum/showth...eady-seen-this
    2018 Audi S5
    Gone-
    Dec 18 2014
    DMV
    So I will say this:
    My 16 S6 that I recently traded in to get my RS7 was tuned. Everyone knew it was tuned. I flashed it back to stock, dealer did spec actual scan, car came back stock, I traded the car and bought RS7.
    I did drive the car about 300 miles after I flashed it back to stock - not sure if that makes a difference. I don't know why it would.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Mar 18 2011
    Denver
    Quote Originally Posted by Serpent View Post
    It actually may make a difference. Conceivable that Audi is looking at ECm-recorded numbesr that may suggest that ECM modification was performed. Things like ignition counts, etc…
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    So I will say this:
    Good info, I may try what you did before taking my car in for next service then. Better time it and set a notification so that I won't forget though.
    Other: 2017 BMW X1
    Oct 06 2006
    2008 Corvette Coupe / 2008 335xi
    Grand Rapids, MI
    The only thing that should change in 300 miles are readiness flags for emission controls... interesting.
    http://shawnkubik.home.comcast.net/c6sig.jpg
    -2008 Corvette Coupe MN6 tinted & tuned CURRENT
    -2002 Corvette Z06 h/c/e 500whp SOLD
    -2004 Subaru Impreza WRX STi, stock turbo, tuned by EQtuning... 12.7@107mph on pump gas. SOLD
    -1999 Audi A4 1.8 turbo quattro SOLD
    -1993 Mazda RX-7 Touring 5spd SOLD
    -1998 Audi A4 2.8q SPORT 5spd, SOLD
    -2002 Audi A4 1.8tqm SPORT/XENON/BOSE silver on black SOLD
    Mar 11 2014
    Dallas/TX
    So I will say this:
    That might make sense like others are saying. The car got flagged, but then later )per the flag removal instructions) the flag fell off seeing the car being stock . We checked at the time of trading in (vin was run in the system) and the car came up clean. I am not sure what happened
    Feb 04 2010
    Manitowoc, WI
    I did not tell them about the tune ahead of time but didn't hide it after. I'm sure if I felt like fighting it, they'd have to pay for the entire repair but it's certainly not worth it for this.
    I just wanted to point out that they can indeed see a tune after flashing back to stock. This was news to me, but I really don't care now that I'm at 56K miles and out of warranty.
    Gotta pay to play.
    Sold: 2009
