Results 1 to 4 of 4
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Question BNS engine crankcase pressure - what shoul it be?
    When the engine idles and you remove the oil filler cap. What pressure should be at the opening? Positive (blow out), negative (suction) or neutral?
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    May 10 2015
    Slovenia
    Anybody?
    James May: "Yes."
    Junior Member Two Rings
    Sep 20 2015
    96 SL500, 2013 Avalanche
    North Battleford, Saskatchewan
    That is an interesting question. I think that it should be positive. Some gasses escape past the valve guides and create a positive pressure in the top of the engine. The crank case and oil sump are the areas of the engine were positive pressure is the largest due to exposure to the combustion gasses escaping past the rings (referred to as blow-by) as well as volatile gases from hot oil within the sump and rest of the engine. Therefore the need for a crankcase ventilation system, otherwise the excess pressure will blow out crankcase seals, among others. I'm not sure if the top and bottom air spaces of the 4.2 V8 is are connected, but I think that they should be or else excess pressure in the valve cover area could blow out the valve cover seals.
    Garet
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    negative ,-1.5hg so vacuum
