Results 1 to 32 of 32
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    SQ5 Suspension / Wheel issue
    I had H&R Street Performance coil overs and adjustable control arms along with new Vff103s installed this week.
    Here's my issue.. Alignment is to spec according to the sheet I received from the shop. They also said it was aligned twice to ensure no issues. The problem is that the drivers side rear wheel sticks out about .5 more than the passenger side. I really can't imagine what the issue is.
    Could the rear cradle/subframe be out of adjustment? My next trip is to the dealer to have them look at it. Visually it's driving me nuts. To the point I'm ready to pull it all off and try something else suspension and wheel wise.
    Thoughts?
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Established Member Two Rings andrios's Avatar
    Aug 30 2009
    IL
    I'm actually thinking about getting those same wheels.
    Could it be possible your offsets are different lol?
    Dec 13 2015
    Houston, TX
    We checked that. That was my first thought too. :-)
    Rebuild Thread
    Aug 30 2009
    IL
    What size/offset wheels did you get?
    sorry im no help on your current situation...
    Mar 13 2014
    Newcastle, England
    nearly all Audi/VW rear subframes sit over to one side, no idea why and no idea if you can fix it.
    Euro SQ5
    C6 Carbon Interior, Exterior and Engine Bay
    Custom yellow stitch and yellow seatbelts
    StillStatic/AH Exclusive Race H&R with custom Air bags (25" ground to fender)
    Aiflift 3P Management
    C6 Carbon Chassis mods
    DTUK Tuned 370Bhp 774Nm
    Rotiform DUS 22x10.5
    Dec 13 2015
    Houston, TX
    How is it that I'm the only SQ person that's had the issue and can't stand it? I haven't seen the brought up in this forum. I found some info on it in one of the VW MKV forums, but nothing here. That's all I can focus on. It's driving me nuts. There's got to be a fix for it.
    Rebuild Thread
    Mar 13 2014
    Newcastle, England
    just add a touch more camber to the side that is out
    Euro SQ5
    Dec 13 2015
    Houston, TX
    I need to post pics because more camber isn't going to fix this.
    Adding camber just masks the real issue here. I'm going to take it to the dealer and see if the my can do a rear subframe move/shift. There's no way it's right.
    Rebuild Thread
    Veteran Member Three Rings Pepper SQ5's Avatar
    Aug 25 2012
    MD
    I haven't noticed it on my SQ and to be honest, I'm hoping that if it does exist, that I don't notice it for the sake of my sanity!
    Nov 02 2008
    2007 BMC SLC01 Pro Machine
    Quote Originally Posted by IanSQ5 View Post
    also very common on BMW's, I've had 4 BMW's all with the same issue...
    Audi Brand Specialist
    Audi Fremont
    [email protected]
    www.audifremont.com
    Dec 13 2015
    Houston, TX
    Quote Originally Posted by pogiFRESH View Post
    Did you fix it? If so how?
    Rebuild Thread
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    yup very common on audi's, i'm not sure about other makes though.
    only way to fix is to unbolt the entire subframe and realign it, then tighten it down. its a HUGE pain in the dickhole.
    Quote Originally Posted by Pepper SQ5 View Post
    THIS. lmao
    Dec 13 2015
    Houston, TX
    Well, I guess I'm going to have pain in my dick hole because I can't tolerate the imbalance.
    Could this have happened as a result of carelessness on a suspension install?
    Rebuild Thread
    Dec 13 2015
    Houston, TX
    Passenger rear:
    Driver rear:
    Rebuild Thread
    Aug 30 2009
    IL
    Ok that's not normal. ^^
    Dec 13 2015
    Houston, TX
    How in the world is that "normal"?
    Rebuild Thread
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    And you're 110% sure that the wheel specs are identical..?
    That isn't 'just a tad off'
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    O. . .M. . .G !!!
    How do you sleep at night?
    Do you still drive it in this condition?
    Dear lord, looks like it might flip over like Fred Flintstone's car at the drive-in.
    Seriously though, manually measure your off-sets.
    They could have been machined one way and stamped another.
    Aug 30 2009
    IL
    Quote Originally Posted by S-Fore View Post
    Voresteiner's SQ5 application on there website has them as different sizes. Mops previous V-ff 103s were different sizes. Fronts are less concave than rears and 9 vs 10.5 width.
    He said he checked them so I'm sure that's not the issue.
    Take it to the dealer.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by JayCar View Post
    holy shit that's crazy. did you get an alignment after lowering??
    i've only seen a difference of about 5mm but when you're slammed in a small car and stancing to the point where you nail the offset down to a mm, it becomes obvious. that is a massive difference though.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    We had a Q5 here about a year or so ago with a set of new aftermarket wheels where one wheel was machined 5mm incorrectly, ended up causing all sorts of problems as the customer threaded the lugs too far in destroying the ABS sensor, hubs and lugs.
    Aug 25 2012
    MD
    what size & offset did you order?
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Quote Originally Posted by Skyler@Achtuning View Post
    holy tits. i did this once way back when i was a noob. luckily didn't shear anything though, just couldn't move then swapped wheels back lol and then next day realized my mistake was using the wrong size lug bolts.
    Sep 17 2007
    who cares what the mfg or website claims....or anyone selling you the wheels for that matter too... We're all human and mistakes happen. id have the wheels off and manually measuring them first thing...
    Easy enough, throw the stockers back on and measure if there is a difference...
    Quote Originally Posted by andrios View Post
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    or swap wheels left to right. take the right one throw it on the left and vice versa. see if you get the same offset.
    Aug 25 2012
    MD
    Simple solution to verify the wheel offsets without taking anything off:
    Take a piece of wood that goes across the face of rim, then use a tape measure to see what the measurement is to the hub (or even the rotor since its just for confirming pad size.) from the wood. IF the wheels are off, then it will reflect in the distance.
    Senior Member Three Rings Qumag's Avatar
    Dec 11 2014
    18'GLC63 AMG, 17' VW Golf Alltrack
    Darien, IL
    I bet my money that's a different wheel offset. A shifted rear subframe would cause a lot of drive line binding and knocking. OP didn't specificy anything like that on the original thread. OP, why would they mess around with the rear subframe for a coilover install??? I had my suspension install and the shop who did mine never once touch or drop the subframe.
    Dec 13 2015
    Houston, TX
    I need to respond to everyone. Busy weekend. lol.
    Rebuild Thread
    Sep 17 2007
    Yeah, what happened???
    Dec 13 2015
    Houston, TX
    Ok folks... Sorry for my delay in response. Funny how a lot of things hit at once. LOL
    I checked the offset on the wheels (Vorsteiners) and they're exactly the same, so it has to be a subframe issue.
    I had the ride height adjusted up some and that GREATLY improved my ride. It was too low to start off with. When we did that, it made the poke a bit less noticeable. It's still there, but not as bad visually. In the end, I think it's going to take a trip to the dealer to get it fixed.
    Between the new suspension, wheels and tires, it was a HUGE visual change from stock. In the end, it looks awesome and handles great.
    Rebuild Thread
    Senior Member Three Rings turrifik's Avatar
    Mar 08 2015
    What was the outcome of this asymmetric poke investigation? Was it ultimately an uneven height issue? Hope you're still happy. Any more pictures of you set up?
    Dec 13 2015
    Houston, TX
    It's actually still uneven, but no one ever notices. lol. I get a ridiculous a pint of compliments and head turns, so I haven't bothered to get the rear cradle aligned. I have posted a couple pics in the SQ5 wheel thread as well.
    Rebuild Thread
