Results 1 to 9 of 9
    Established Member Two Rings Lookslikelotion's Avatar
    Aug 01 2014
    PA
    Where did you put your chipwerk tuner at?
    I recently got myself a chipwerk pro tuner but I'm curious as to where everyone else has put there's so that it stays dry
    & also isn't near anything that gets to hot
    IG: @kevindellavecchia "In Us We Trust" -The Clique Forever
    Mar 21 2015
    Look in the CW thread
    Oct 14 2012
    Empty...for now...
    SE PA
    I mounted it to the back of the Homelink transmitter on the back side of the stock grille, using heavy duty 3M plastic velcro (the stuff they use for EZ Pass transponders).
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    work hard, play hard[;)
    Aug 01 2014
    PA
    Quote Originally Posted by PinoyS4 View Post
    I put mine there also & feel like it's a shitty spot to try & keep it dry😅
    Aug 12 2013
    Lexington KY
    What the heck, am I blind. For the life of me, I don't see the unit in the above picture.
    - - - Updated - - -
    Oh wait, strike that: I see it. Passenger side wheel well.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Lookslikelotion View Post
    Back when I had a Chipwerke S box, I toyed with the idea of applying some clear RTV sealant around the connection between the cable and the box to minimize/eliminate water contact or ingress at that area, but I never got around to doing it. Meanwhile I had mine mounted to the backside of the Homelink transmitter on the rear of the stock front grille, which is above the area of the grille that is open to the front. I drove through many rain storms and washed the car frequently and never had a problem. Water doesn't want to flow against gravity, and unless I were to have pointed a hose into the grille slats and point it upward, I do not think there was any way for a significant amount of water to contact the box directly. If I would have run into a deep puddle head-on, possibly it would have caused an issue.
    Aug 12 2013
    Lexington KY
    I've got the RS Honeycomb grill though. Do you guys see that as a problem?
    Jul 21 2004
    South Florida
    I put mine behind the driver side headlight. It stayed perfectly dry.
    Mike
    2018 Audi S5
    Gone-
