Results 1 to 5 of 5
    Registered Member Four Rings German Driver's Avatar
    Aug 08 2004
    '06 SPORTEC A4 2.0T Avant
    Boca Raton, FL
    Overview of the Audi Telematics
    Navigation Plus: Your general overview of the RNS-E and the useful features it provides.
    The Audi Navigation Plus is a DVD based navigation system which became available as an option on US MY2005 or 2005.5 and onward A3/A4 automobiles. The A6 and A8 also use a similar built in MMI system which is basically the same as the RNS-E. First released in Europe in the earlier platform cars, the RNS-E is the successor to the older RNS-D, and the CD based Navigation Plus, which was only available in Europe and the US Audi Navigation found in TT's, S4's, A6's, and A8 model line cars.
    The current Audi Navigation Plus utilizes a user friendly design and is a complete OEM option. It offers the user with a DVD navigation interface with the ability to play DVD maps and audio CD's. Another popular and unique feature on the RNS-E is the SD card bays located behind the motorized LCD screen. The SD card slots, otherwise known as secure digital, provide the operator to save hundreds or even thousands of MP3 files for immediate playback which can also be categorized in folders and sub folders for easy selection and organization. Artist and track names can be easily displayed on the DIS (Driver Information Display) located in your gauge cluster between tachometer and speedometer. You can set ID Tags to your personal preference even if you wish.
    The navigation itself operates off of a single NavTeq DVD map which covers all of the continental US and Canada as well as Alaska and Hawaii. It allows for the option of the OEM glove box mounted 6 disc CD changer, Audi Phatbox, and with proper connections, even your Apple iPod. This does not however limit you to just those options. Video game systems, DVD players, and various other audi video equipment is still an option when working with the system. This unit can be retrofitted for direct plug and play if your car is already equipped with the Symphony II head unit with Bose or non-Bose audio system.
    A3 A4 A6 shown above (in order)
    Aug 08 2004
    Boca Raton, FL
    Bluetooth Technology
    Bluetooth Technology: Information regarding advancements of Bluetooth technology and your Audi.
    Content coming soon!
    Aug 08 2004
    Boca Raton, FL
    Audio/Video & Peripherals
    Audio/Video & Peripherals: Information regarding all of your A/V setups as well as what does and does not work with your OEM setup.
    Dietz 1417 Multimedia Adapter Module
    The 1417 is the linking module which relays the video from the external source to the actual RNS-E. This is necessary for video to be displayed but without mating with the 1280 will result in video to not be displayed while car is in motion.
    Dietz 1280 Video in Motion Module
    This particular module allows the driver to view video from external source such as DVD player, PSX2, or other similar sources. Without this module video playback will be cut from the screen at point when car has been engaged into a gear.
    To place an order on anything you see above shoot an email over to [email protected]
    Aug 08 2004
    Boca Raton, FL
    Adapters, Cables, & Antennas
    Adapters, Cables, & Antennas: Information pertaining to the wiring of various multimedia and telematic features of your Audi.
    GPS Antenna
    This handy cable has a FAKRA adapter on the connector end and ceramic ping antenna on the other. The face of the antenna also provides a magnetic source which assure that it always faces in proper direction for optimal reception. Certain surrounding materials can cause satellite disruptions. Length is determined by manufacture. Extensions available if need be. Unit is generally routed beside fuse panel for ease of use if you need to get at it. Generally taking just 3 feet of cord. Extensions are generally used for routing to your shark fin antenna atop your roof. Access FAKRA points are located behind the plastic panel at the top of your rear windshield positioned directly in passenger C pillar.
    Bose Wiring Harness
    This wiring harness is specific to your Bose audio package from Audi. At a minimum your harness will have 2 connector heads. This particular harness allows for TEL and CDC capabilities. You are able to tell this by the third connector head.
    Non-Bose Wiring Harness
    This harness is meant for a non-Bose application. It utilizes minimum of 3 connector heads 3rd being for speaker integration. Picture shows harness capable of CDC and TEL functions.
    FAKRA to Diversity Adapter
    In general this cable allows for radio frequencies to be transmitted to RNS-E. The dual adapter head allows for your iso input from your cars current harness. You will need to remove a green FAKRA connector which utilizes a purple retainer clip such as that shown in the image and place it into the dual opening show above.
    All products shown above are readily available from Rival Motorsport. Please contact [email protected] for support and purchase information.
    Aug 08 2004
    Boca Raton, FL
    SAT Reciever for Sirius and XM Radio
    SAT Reciever for Sirius and XM Radio: Information pertaining to your Sirius and XM SAT Recievers for your OE Audi application.
    OE Sirius SAT Reciever
    This particular p/n is needed to operate your SAT radio with the RNS-E unit.
