Results 1 to 4 of 4
    Active Member Two Rings 75sana's Avatar
    Apr 27 2016
    ST. Louis
    Satellite shark fin antena replasment on 13 Allroad P+
    Did anyone attempt this . My dealer tells me that I need new fin antenna because my Sirius radio does not work. They did test I guess with Diagnosis; 02617 011 satellite antenna (open circuit static). I purchased used one from ebay. Please any input will help.
    Loooong ago; 1987 Audi 80
    Long ago; 1991 Coupe Quattro
    Now; 2013 Allroad P+
    Other vehicles; 1990 300 zx
    1997 Ford Probe GT
    2001 Acura CL
    2013 Accord Sport
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    I haven't changed mine specifically, but I did put together a headliner removal thread for my B8 a couple of weeks ago. There may be some slight differences between your headliner and mine being that yours is an allroad with a pano roof, but I think you'll really only need to drop the back portion of your headliner. I assume this would be pretty easy in your case, because you have lots of access with the back hatch up. The second to last picture in the first post of the thread below shows you the antenna from the underside.
    http://www.audizine.com/forum/showth...dliner-Removal
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I assume your Allroad will be the same as my Avant. It's quite easy to access and remove the antennae. Remove the wide headliner trim piece at the rear edge and you can pull down the headliner enough to access the single nut that secures the antennae and unplug the wire connector. The trim piece is held on by metal spring clips like those shown in the D pillar trim photo in the DIY.
    2011 A4 Avant
    Apr 27 2016
    ST. Louis
    Thanks guys.
    1997 Ford Probe GT
    2001 Acura CL
    2013 Accord Sport
