Hello everyone! I’m new in your forum. I’d like to ask you if you have any idea what’s wrong with my air conditioning in Audi A4 2004 (B6). It's not blowing cold air at all. The AC has just filled with refrigenerant but the problem still exists. There are no fault codes and the adaptation in VCDS is fine. No problems with the econ light either.
According to Measuring Value Blocks(MVBs) it seems for me that the compressor is running normally (Group 002: Last Compressor Shut-Off Criteria). Any idea what could cause the problem?
Below the information of MVBs. Thank you in advance!
Thursday,05,May,2016,10:07:39:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Address 08: Auto HVAC (8E0 820 043 AB)
10:07:26 Group 001
0.648 A A/C Valve (N280) Current
64.0 % A/C Valve (N280) Duty Cycle
22.5 % High-Pressure Signal (G65)
6.0 bar Refrigerant Circuit Pressure
10:07:26 Group 002: Last Compressor Shut-Off Criteria
0.0 Current Criteria
0.0 Last Criteria
0.0 Last but one Criteria
0.0 Last but two Criteria
10:07:26 Group 003: Left Temperature Flap Control Motor (V158)
22.0 Current Value
19.0 Specified Value
22.0 Minimum Position (Cooling)
229.0 Maximum Position (Heating)
10:08:10 Group 004: Right Temperature Flap Control Motor (V159)
22.0 Current Value
230.0 Maximum Position (Heating)
10:08:10 Group 005: Defroster Flap Control Motor (V107)
114.0 Current Value
115.0 Specified Value
25.0 Minimum Position (Lower Stop)
227.0 Maximum Position (Upper Stop)
10:08:10 Group 006: Central Flap Control Motor (V70)
220.0 Current Value
223.0 Specified Value
35.0 Minimum Position (Lower Stop)
220.0 Maximum Position (Upper Stop)
10:08:48 Group 007: Air Flow Flap Control Motor (V71)
22.0 Current Value
22.0 Minimum Position (Lower Stop)
233.0 Maximum Position (Upper Stop)
10:08:48 Group 008: Air Recirculation Flap Control Motor (V113)
205.0 Current Value
208.0 Specified Value
33.0 Minimum Position (Lower Stop)
205.0 Maximum Position (Upper Stop)
10:08:48 Group 009: Temperatures I
39.0°C (102.2°F) Left Footwell Vent Temp. (G261)
37.8°C (100.0°F) Right Footwell Vent Temp. (G262)
28.2°C (82.8°F) Left Vent Temp. (G150)
28.2°C (82.8°F) Right Vent Temp. (G151)
10:09:23 Group 010: Temperatures II
26.0°C (78.8°F) Evaporator Outflow Temp. (G263)
28.0°C (82.4°F) Fresh Air Intake Duct Temp. (G89)
11.5°C (52.7°F) Calculated Ambient Temp.
22.5°C (72.5°F) Measured Ambient Temp. (G17)
10:09:23 Group 011: Temperatures III
26.5°C (79.7°F) Dash Panel Temp. (G65)
3240 /min Temp. Sensor Blower Speed
90.0°C (194°F) Coolant Temperature
ON Idle Speed Increase Request
10:09:23 Group 012
874 /min Engine Speed
0.0 km/h Vehicle Speed
0 Compressor Torque Status
4.0 Nm Required Engine Torque
10:09:51 Group 013
37.5 % Fresh Air Blower Actuation (V2)
1720 /min Fresh Air Blower Speed (V2)
100.0 % Status Terminal 58d
0.0 % Status Terminal 58s
10:09:51 Group 014
23.2 % Radiator Fan (V7) Requested Value
8.8 % Radiator Fan (V7) Actual Value
Not Installed Air Quality Sensor (G238)
40.0 Fresh/Recirculated Air Request
10:09:51 Group 015
R.wn.h.OFF Rear Window Heating (Z1)
Not Installed Front Window Heating (Z2)
OFF Axiliary Heater Actuation
Not Installed Convertible Top
10:10:20 Group 016: Sun Intensity (G107)
1.74 V Sun Intensity Left Side (G107)
424.0 Sun Intensity Left Side (G107)
1.40 V Sun Intensity Right Side (G107)
308.0 Sun Intensity Right Side (G107)
10:10:20 Group 017
ON Status Terminal 15
ON Status Terminal 75
14.00 V Supply Voltage (Terminal 30)
10:10:20 Group 018
00:06 Time
1 Key Number (Ignition)
00000 Windscreen Wiper Status
49.0 % Fresh Air Blower (V2) Duty Cycle
10:10:47 Group 019
0 1 001 Bin. Bits
0 0100 Bin. Bits
Bin. Bits
Bin. Bits
10:10:47 Group 020: Seat Heating (Driver)
0.0 % Switch Position (knurled Wheel)
26.4°C Temperature Actual (G59)
-99.0°C Switch Position (knurled Wheel)
OFF Seat Heating (Passenger)
10:10:47 Group 021: Seat Heating (Passenger)
21.6°C Temperature Actual (G60)
10:11:17 Group 022
OFF Auxiliary Heater (J364) active
0000 Auxiliary Heater Signals
OFF Fresh Air Blower Requ. by Aux.Heat.
3771.4 s Maximum Aux.Heat. Active-Time
10:12:02 Group 026: Fault Code Conditions I
Erased Deactivation Fault Code
Erased Refrigerant Circuit Pressure
Erased Radiator Fan (V7) Requested Value
Erased Radiator Fan (V7) Actual Value
10:12:02 Group 027: Fault Code Conditions II
Erased Calculated Ambient Temp.
Erased Vehicle Speed
Erased Coolant Temperature
Erased
