Results 1 to 20 of 20
    Dec 11 2015
    Syracuse,NY
    Question Bilstein B16 too hard for me...NEED HELP
    Hi guys I recently put Bilstein B16 on my car. The car is pretty low now and I'm very happy about that. However I feel like B16 is too hard for me...considering I live in upstate NY and the road we have super bumpy...I had level 5 on both front and rear and right now is level 3 on the front and level 1 on the rear...still super bumpy and too hard for the road
    Any suggestion to solve this problem? Like a new set of spring? NEED HELP!
    Update: Seriously thinking the combination of s3 shocks+ Emmanuele Design springs, any comment on this set up? Also does anyone know what is the part number for S3 shock..?
    2015 black A3 Premium---APR stage 2+DSG tune, APR carbon fiber intake, Bilstein B16 PSS10. USP downpipe, Milltek non-resonated catback. emmanuele design carbon fiber rear spoiler
    Sep 07 2012
    Singapore
    Are you on stock or aftermarket sway bars? Try switching back to stock if you are on aftermarket sways. It helps for bumpy roads.
    Dec 11 2015
    Syracuse,NY
    Stock..
    Honesty I'm thinking S3 shocks+lowered spring combination right now
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    bilstein might have different spring options for this coilover setup .
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Dec 11 2015
    Syracuse,NY
    Quote Originally Posted by diztek View Post
    I checked...nah
    Apr 27 2010
    West Chester PA
    Tire pressure plays a huge role as well as tire size. Not sure which setup you have or tire pressures. It is all subjective too, maybe you aren't about that racecar life.
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
    Dec 11 2015
    Syracuse,NY
    39psi with 17 inches rims+225/45
    Apr 27 2010
    West Chester PA
    Oh wow. that is a soft setup to begin with then. You could lower tire pressure. Is this your first set of coilovers? Obviously know nothing of who you are or cars you've owned, but that should be a nice setup.
    Dec 11 2015
    Syracuse,NY
    Yup and this is my first car :) Thanks for your advice
    I tried many setup with b16 and I think it is just because the road we have is super bumpy. I actually had level 5 on front and rear for a road trip to PA, spent an afternoon in west chester, super comfort and I had no problem with it. But upstate NY? The road we have are like bombed
    Established Member Two Rings 15WhiteA3's Avatar
    Feb 12 2015
    Harrisburg
    What fender height are you? You may be too low for the system. If I recall there a 20 mm range in adjustment on them.
    B8.5 Q5 3.0T-Glacier White, Black Optics, S-Line Interior Package.
    B8 S4 Stage 3 Phantom Black-SOLD
    8V A3 State 1+ Monsoon Grey-Ex Took
    2004 Titan- Work Truck
    Dec 11 2015
    Syracuse,NY
    never measure the height, but the front is pretty low, like 5mm until the lowest point
    Apr 11 2012
    Dec 11 2015
    Syracuse,NY
    hahahahahaha
    Feb 12 2015
    Harrisburg
    You might be too low that could be why. Mine are around the middle of the adjustment area and mine rides amazing. I don't have the adjustment you do since I have the b14 kit but mine is comfortable even with pa roads.
    Dec 11 2015
    Syracuse,NY
    PA roads are so much better than what we have in syracuse ;(
    Account Terminated Four Rings
    Sep 13 2014
    New York
    It could be the polyurethane mounts on front struts. This is a warm weather track suspension. It's not good for the street. If you don't like it now forget when it's 20 degrees out. Lowering the adjustment to low numbers is defeating the purpose of this system.
    Dec 11 2015
    Syracuse,NY
    This actually makes sense, I can feel the differences under different weather
    Established Member Two Rings salvadorik's Avatar
    Mar 03 2015
    Fremont/CA
    I always thought that B16 in its comfiest setting provides with a more comfortable ride than the OEM setting (say S3 with mag ride with comfort mode selected). Of course once lowered and adjusted coils to a sporty mode they will be stiffer. What I dont understand is how OE S3 shocks (regular shocks) coupled with ED springs can be more comfy than B16 in its comfy setting as well. Isn't the following true with B16:
    comfort mode:
    B16 is more comfy than the stock set up
    normal mode:
    B16 is about equally comfy as the stock set up
    sport mode:
    B16 is really stiff and significantly less comfy than the stock set up
    Please note at all three variations listed above B16 offers significantly better handling. Frankly speaking I didnt drive a car equipped with B16 and my opinion is based on what I read and heard. OP are B16s that uncomfortable that you are considering go back to stock setup?
    2015 Audi S3 8V - Sepang Blue - Prestige Pack - 19 Performance Pack - Advanced Tech Pack - Clear Bra - Ceramic Tint (50% font and 5% rear) - H&R front and rear sway bars - Eurocode ÜSS (MQB) rear chassis brace - K&N high flow air filter - Unibrace UBQ - 034motorsport rear subframe mount inserts
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Being that low, the springs are really compressed (sounds like to spec limit?). Softening the damping won't help wheel travel. The axles/wheels need a certain amount of travel to absorb the impacts. My suggestion if you don't like the current ride hardness is to raise her up a little, maybe even to Euro spec. Riding at the lowest height will give you the roughest ride.
    Or you can bag it. Slam it when you're outside the car and can see the stance, then raise it when driving.
    Either way, car is to low to ride soft IMO.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    May 13 2011
    2015 BMW F30
    Quote Originally Posted by will13k7 View Post
    Lol
    | Autospeed | JHM | Pure MS
