Results 1 to 17 of 17
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Question Back at it again with the control arms...
    Hey guys,
    So I'm here yet again with replacing my front control arm bushings. These ones lasted me about 35k miles... is this average? I was exploring some other options rather than the OEM rubber ones. I came across PowerFlex which look to be good quality but I wanted to see if there was something else out there that I was missing. I don't want to replace the entire set of controls arms with aftermarket. The OEM part numbers needed are listed below.
    Audi VW Control Arm Bushing Front Lower Front Inner - 4D0407182G
    Audi VW Control Arm Bushing Front Lower Rear (A4 A6 S4 Passat) - 4D0407183AC
    Audi VW Control Arm Bushing Front Upper - 8D0407515C
    Should I just go with the OEM rubber ones and bite the bullet yet again or is there anything better out there? Thanks in advance!
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Oct 24 2015
    Perth, WA
    subscribed
    My respray thread
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by Obsidian View Post
    Hey guys,
    Email the guys at FCP Euro and see what they say. Some if not most of their parts have lifetime warranties.
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    Here are a few lesser known upper poly options....
    http://www.ebay.com/itm/AUDI-Passat-...item4aee3c7048
    http://www.ebay.com/itm/PU-Bush-Fr-S...-/151895982280
    And here's a pair of inexpensive poly lower forward inners(repl. 4D0407182G)...
    http://www.amazon.com/2001-2008-1997...ilpage_o04_s00
    ll Audi Sport "Vorsprung Durch Technik"
    Mar 24 2013
    Oakdale, CT
    35k miles from OEM bushings is not average. Most cars don't need them until around 100k miles. It sounds like a possible install error.
    -Adam
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    The first link is whiteline. They are quite reputable in the subaru world
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Hmm... could have been. I talked to the rep at 034 Motorsport and he said average is in between 35-50k. I don't know whats what when it comes to this so I'm in the dark. I installed the FCP kit at about 75k and just kicked over 105k. Anyhow, I ended up ordering a density line kit from 034 so hopefully this one will last me longer. Reason I went with an entire kit is because it was actually going to cost be the same amount to just replace everything rather than just the bushings, since labor is a killer to press the bushing in and out. Also I was told by two ppl that the rubber bushings tend to fail quicker here in AZ since its so damn dry and hot, which could have been a influence on my current failure.
    Mar 24 2013
    Oakdale, CT
    Yeah the AZ weather may be a factor in the early failure. I'm running FCP control arms and have had them on for about 30K miles now and there's no sign of them going bad anytime soon.
    -Adam
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    I'm not sure why, but I've always liked the feedback/front handling feel on the VAG multi link set-up. Guess that's why I've been driving them for so many years. That being said, the rubber control arm set-up sucks for longevity. It should last 100k but if you lower or change the geometry at all they don't. I've been tempted to go with power flex bushings and use my press to swap them out. Think I'll do it on my E36 too since they get good reviews on that platform.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by 67Twisty View Post
    That's probably because most people don't loosen and retighten the bushing bolts at the new ride height.
    -Adam
    Jul 11 2015
    North Carolina
    Likely true. But I had a local shop I trust do it once and I DIY'd it once. Both times resulted in failed OE bushings in under 30k and I'm not particularly low (Eibach/Koni yellows). Maybe I got new old stock rubber or the shop and I both miss-measured. Stock rubber is good for comfort but modern poly will way outlast it.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Which poly bushings do you have?
    Jul 11 2015
    North Carolina
    I installed Nylatron NSM on my TR. They're self lubricating so you don't get the squeaking like on regular poly. That car is on shorter track springs and so far they have performed excellently. Powerflex are supposed to be a good mix between the comfort of rubber and longevity of poly. I was leaning towards using them on the Avant but went with the FCP forum discount based on the mostly positive reviews here. I saved the OEs and will press-in Powerflex if they too are short-lived. Downside is you do have to grease them from time to time.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Dec 04 2011
    Kansas City, KS
    Just be liberal with cobber grease when installing and they should be pretty good. When i do my control arms im getting powerflex black for sure
    Feb 15 2016
    Cambridge,Ontario
    I have my own press so getting bushings will be the way for me to go too. 35K seems shockingly low to me. I am at stock height and I would hope to get at least 70 K out of them . I m going to keep an eye on this thread to et an idea of what is recommended. I imagine Poly would transmit vibration and be a harsher ride no ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 11 2015
    North Carolina
    35k is low and I'm not trying to suggest it's normal. But the multilink set-up was designed for factory ride height, wheels, hub spacing, etc. Change any of these parameters and the suspension will wear differently. Locking down the CAs at the revised ride height is crucial, but you've still changed the original design geometry. There's also not much adjustment built into the stock design. That's why vendors offer adjustable CAs and that's also a factor in why CV joints/axles can wear prematurely.
    This is my daily and I have a long commute, so I'm trying to balance comfort with performance. I have polys on a couple cars. It does stiffen things up, but I don't find it harsh. Just less of a "touring" feel.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Dec 04 2011
    Kansas City, KS
    I feel as though poly isnthe way to go with our setup. A lot of the bmw guys are happy with powerflex black
