Results 1 to 2 of 2
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Timing completed exhaust question
    I have driven about 50-80 miles on new tensioners, guides, and mechanical adjusters.(much more of course)
    I also replaced header gaskets, and bolts also. Tightened them real good.
    But I have noticed that my car seems a bit loud. But nothing to crazy. Seems to be loud in the cabin.
    I had trouble mounting the downpipes to the transmission using those mounts/ bolts. They wouldn't line up correctly for me. And I got lazy. So I just ended up not bolting up the downpipe, to the tranny.
    Would this be the reason why it seems loud?
    Could someone please re-assure me that it is not the manifold?
    Thank you!!
    P.s. Now that timing is all done. I can now hear my intake flap. Yay me!
    Sent from my SM-G900T using Audizine mobile app
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Downpipes/piggies/stock cats have to be angled correctly or the flared end will not seal correctly. I almost never bolt the downpipes to the transmission but since I angle the pipes correctly then it isn't a problem. Good luck with the car and you have been through a lot with this car so I hope that you really get to enjoy it!
