Originally Posted by
PreciseD
??? I know of thousands that has happened too. Myself included.
You know of thousands of cracked 1.8T cylinder heads that leaked coolant into one or more cylinders, including your experience, through crack/s, that were confirmed by a water tank test? I don't believe you can provide even one confirmed example of this actually happening. The configuration of the casting just doesn't crack in a way this could happen. If there was any technical factual merit to this unsupported allegation, Audi/VW would have redesigned the casting. All of the alleged cracked heads leaked from some other cause, like a failed head gasket. When the head is replaced with a new head gasket the leaks were fixed, so those who don't understand the facts involved believe the alleged cracks in the old head were confirmed by the fact the new head installation did not leak coolant into the cylinders. Duh. I am not going to debate this further, it seems to be a waste of my time.
I apologize for the terse writing style I have, I don't mean to offend you from a personal aspect.
*Terse: " brief and direct in a way that may seem rude or unfriendly"
