Results 1 to 8 of 8
    Jan 09 2013
    ___
    Repair or replace cracked water pump?
    My S4 has been sitting for quite some time and I was starting to get it back in working order, and I noticed the coolant was leaking. I raised the car up and found a small crack on the bottom where the coolant pipe connects. Is this a common issue? Is there any reason why I shouldn't weld the crack (and replace any o rings by the connection) rather than replacing it entirely? It's just where a hose connects, it doesn't appear to be on the housing where any moving parts are. Before anyone mentions it, yes, I know coolant is flammable. The coolant will be drained and the area cleaned before any welding occurs.
    Here is a link to some pictures. Excuse the dried coolant all over the place!
    Established Member Two Rings gaben2racin's Avatar
    Jun 15 2013
    Roseville,CA
    Coolant is flammable. Ohh man. Here we go.
    Sent from my SM-G900T using Tapatalk
    Jan 09 2013
    ___
    Quote Originally Posted by gaben2racin View Post
    Did you even bother reading the full post? I clearly acknowledged this, but it's like you wanted to start arguing/insulting from the start.
    Aug 09 2012
    Bay Area
    He is right. Pure coolant in itself is flammable but once diluted with water tho it becomes significantly less.
    Jan 09 2013
    ___
    Quote Originally Posted by Kambesama View Post
    He is right. Coolant in itself is flammable but once diluted with water tho it becomes significantly less.
    Yes, I mentioned this in my post. What are you guys going on about?
    Aug 09 2012
    Bay Area
    Quote Originally Posted by tmh88 View Post
    Oh nothing don't mind us haha. Which part is leaking/broken? Is it the part where the drain plug is at next to the lower radiator hose? Anyway you can snap a picture to make it easier? I believe the water pumps are made from aluminum, not 100% sure tho.
    Jan 09 2013
    ___
    I included a link to some pictures in my post.
    Jun 15 2013
    Roseville,CA
    Nope not trying to argue. Just stating I have yet to see coolant go up in flames.
