Results 1 to 15 of 15
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: ECS RA4 240mm Clutch Conversion Kits | Audi B6 A4 1.8T
    Give your B6 A4 1.8T the clutch it deserves. We've assembled three very special clutch packages built around the ECS Tuning RA4 lightweight flywheel.
    Mate our low mass flywheel - 12lbs to be exact, to a bigger 240mm clutch! Choose S4, RS4, or Clutch Masters RS4 clutch kits for a smooth, powerful clutch/flywheel package that revs faster but won't forget its manners in traffic.
    No modifications required. Bolt them on and go, with complete kits that include everything you need, right down to fresh bolts and a clutch alignment tool.
    Make the Switch.
    Fitment:
    Audi B6 A4 1.8T 2002-2005
    Jason
    Active Member Three Rings
    Feb 10 2015
    seattle
    Hook up the discount! I'll buy one today
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by b1337 View Post
    We actually do not offer any specific discounts as we try to price our products as competitive as possible so everyone can take advantage of the same savings.
    Never hurts to ask though!
    Jason
    Established Member Two Rings Europotvin's Avatar
    Feb 03 2015
    Sherbrooke Quebec
    I am looking for a clutch setup for my A4 1.8t 6mt with a TDI swap. I was wondering if you offered any single mass flywheels that were not ''lightweight'' since they are not recommended for diesel engines. I would love to go to a 240mm setup for the extra torque capacity it will hold.
    APE - Automotive Performance Engineering http://automotiveperformanceengineering.com
    A4 B6 TDI 6spd
    BUILD THREAD: http://www.audizine.com/forum/showth...o-Diesel-Build
    INSTAGRAM: euro.po
    Feb 10 2015
    seattle
    group buy!!
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Europotvin View Post
    We have a single mass flywheel conversion kit that isn't light weight for the 1.8T but its not 240mm.
    Click HERE
    group buy!!
    We don't offer group buys either unfortunately.
    Jason
    Feb 10 2015
    seattle
    i like to try every possible angle :)
    Oct 02 2006
    Wadsworth,OH
    I don't blame ya!
    Jason
    Feb 17 2004
    Liberty Hill, TX
    just a warning for 5-speed owners: http://www.audizine.com/forum/showth...ch-Replacement
    as a current stage 2 RA4 owner, I have to concur with the OP of that post, and would say that it's somehow actually significantly worse than my previous stage I JHM RS4 kit, which uses a lighter aluminum flywheel. I'm actively searching for a 6-speed to swap in, it's that bad =/
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Matt Devo View Post
    I have our RA4 flywheel in my B6 with a 5spd and it definitely has some serious vibration under 2000RPMs if you're just lugging along. This is normal. The RA4 flywheel doesn't dampen half the vibrations the dual mass would under those conditions. Personally I don't mind it because I'm hardly ever in the wrong gear or loading up the vehicle up like that. It may take some adjusting if you're used to cursing around in the highest gear though. It's not for everyone that's for sure, but not every modification is.
    Jason
    Feb 17 2004
    Liberty Hill, TX
    I have that vibration all the way thru 3200 or so, esp if lifted off the throttle and engine braking
    Oct 02 2006
    Wadsworth,OH
    I haven't watched specifically where it stops but if you're in a high gear and under a moderate amount of load you'll get some increased NVH for sure. As such if you let off and engine brake below 2000 rpms. Not sure why you would want to do that anyways.. especially if you have another gear you could be in.
    Jason
    Feb 17 2004
    Liberty Hill, TX
    Jason
    If I'm around 3k rpms in 3rd and need to slow down slightly, it doesn't make sense to downshift to 2nd just to engine brake, and that's where I'm getting the gear rattle.
    Oct 02 2006
    Wadsworth,OH
    Like I said it's the nature of the flywheel. Not really anything you can do about it but change your driving habits if you don't want vibration. The way I drive I hardly ever experience vibrations. It's usually if I'm going up a hill in too high of a gear or happen to be on that cusp between gears were you could down shift. Or give it gas, vibrates for a second, then it's above the RPM range where it smoothest out.
    Jason
    Jul 14 2009
    Pasadena
    Quote Originally Posted by 878roby View Post
    Can this clutch kit also fit on A4 B6 1.8T Quattro 6 speed manual.
    I ađ asking this because they have some parts different than rest 1.8T's.
    If not sure, can you check with VIN vode?
    yes
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
