Results 1 to 6 of 6
    Junior Member Two Rings
    Jul 01 2014
    Upstate, NY
    C5 A6 Wheel Offset
    I am always uneasy about wheel offset when looking at wheels to buy. Looking at a set of 18x8 wheels with a 45mm offset from a newer VW, and curious if anyone can provide some fitment info. Will that offset work, will the wheels poke out etc... etc... When I look up the same set of wheels on Tire Rack for my 99 A6 Avant it recommends a 32mm offset? Thanks in advance!
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Even if ET45 would clear the brakes and suspension they would probably look a little goofy since they would stick too far inboard. Lower ET moves the wheel farther outboard.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Jul 01 2014
    Upstate, NY
    I just looked up the OEM offset, and it was 45mm. Used an online calculator to figure the difference from my 16x7's to the 18x8's, and it said the wheel would be 13mm inward. So I'm thinking I will move forward with the wheels, and grab some 15mm spacers to make it work. Anybody that can confirm?
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Also keep in mind the hub bore will be different, 57.1 mm vs 66.6.
    Jul 01 2014
    Upstate, NY
    Quote Originally Posted by carmudgeon View Post
    Wheels I'm looking at came off a 13' Volkswagon. Think it's the same 57.1 bore.
    Jul 01 2014
    Upstate, NY
    Well this about sums it up, I guess I will need to determine what size spacers I will need:
