I used to get a fuel pressure code, and it wound up being the fuel filter (by the tank). The car has two fuel pressure sensors--the one on the hpfp, and the lpfp. If you have VCDS (or get someone close by), then you can get it checked out in more detail.
When was the last time plugs and coil packs were changed as well?
