Results 1 to 10 of 10
    Jun 15 2010
    Chicago
    Questions for those with headers and lightweight crank pulley!
    Thinking about these as my next two mods. For those who have headers with an aftermarket exhaust system, did the addition of headers cause more drone inside the car? I know it makes the exhaust louder and higher pitched but does it add any drone?
    And for those who got the overdrive crank pulley, how hard was the install and any DIY guides? Also, for those with Stage 2 and the overdrive pulley, what belt do you use?
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Yes, the test pipes will add drone. Maybe tolerable if you have AWE touring with Resonated DPs... But not my cup of tea for this car.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    You'll want to do more research on the headers. But I've heard real world gains are minimal (if any) and given the $-tag not sure it's a worth while investment.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I thought Primetime or someone found test pipes or HFC was just as good if not better than the cost of the headers.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Waste of money. Save the money and go dual-pulley + cooling, which will see real gains.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    FWIW, headers sound glorious on this platform.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Deactivated Four Rings
    Jun 23 2011
    And what about some dual pulley software? or dual pulley with E85 ;)
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Another cheaper option is to run test pipes with a set of 3.2 manifolds.The restriction with our manifolds is the flange that bolts up to the test pipe.It is tiny! I found a set of 3.2 manifolds for $50! And they have a much bigger outlet.
    Just another option if you guys didn't already know.
    Sent from my SM-G900W8 using Tapatalk
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Quote Originally Posted by s4matty View Post
    Interesting, so it will just bolt right up? Any of the audi 3.2 exhaust manifolds have the same flange as our 3.0t?
    Aug 15 2015
    2 feet
    Niagara canada
    The ones I picked up came off a Q5..But yes any of the later models bolt right up.
