Results 1 to 14 of 14
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    Stage 1 effects on stock cat
    So I am thinking of going Stage 1 sometime this summer and I am wondering about how a 126K stock cat will do with the tune. (I imagine it will but) Will it effect the life span of the cat? And/or melt it? This is all important since I live on California (and our strict smog laws), plus I don't really feel like spending $750 for a new cat
    Thanks
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Jun 10 2010
    Don't matter.
    Mar 20 2016
    Don't matter.
    I mean, it kinda does. I don't want to be exactly blowing through cats here I know that is an exaggeration but I want some idea of what it will do to the cat. It will definitely run hotter at least.
    99.0 B5 A4 1.8TMS
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    It's fine. My car has been stage 1 tuned for 100k miles and still passes smog with the original cat.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Have well over 100k on my stock cat tuned since like 04 on various tunes threw out the years.
    All gone now but I'll go back 2 cat for smog, don't think my turbo or manifold will let me pass neways tho
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    Quote Originally Posted by Mattr567 View Post
    no, not really.
    before getting a test pipe i had 100k on a stock cat as well
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    What's really neat is unbolting the cat , running a test pipe, and then reinstall for emissions.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    I feel bad for your guys with all this emissions BS. Out here everyone has a test pipe. I personally don't I have a hollow CAT. But before I did I was running my stage 1 with a cat for like 10k it already had 85k and I never had a problem.
    Nov 27 2010
    mass
    i only have to pass safety for inspection. I dont think ive got any factory emissions stuff left.
    Feb 27 2011
    Winnipeg
    just make sure the car is running properly before you get it tuned. Missfires are the #1 cat killer, if your coils are old or plugs are old deal with that first, raw unburnt fuel along with the extra heat being generated from more boost with a tune will finish off your cat if your car isnt in perfect running order.
    Jul 07 2009
    Socal/IE
    Quote Originally Posted by MarcRogers View Post
    hardly bs. all one has to do is compare the cali smog before and after emissions laws fresno and bakersfield excluded. i think its better this way and us that want performance just do a few things b4 smog or "know" someone. we only have emissions no real safety inspections or any of that nonsense.
    what is bullshit is the dui style smog checkpoints. honestly cops hardly care unless ur a douche with a flat brim or look excessive modded. they are more worried about the clapped out beat to shit 90s cars dumping black smoke out the back.
    Dec 05 2007
    Runing rich is what really ruins cat converters, from stock to modded.
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I tuned at 60k im now at 99k and my cat has a rattle in it. Still passes emissions and very likely just normal wear and tear from heat cycling over 15 years. I still pass emissions it just rattles at idle
    Jul 07 2009
    Socal/IE
    Just found out CARB is moving its headquarters to my city and the university where i work. Not excited I'm sure they will be super Nazi around my area now.
