Results 1 to 7 of 7
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    Deformed AWE Intake?
    I bought an AWE intake used, and when I started the install, I noticed what appears to be a deformed component. This is the part that attaches to the rubber adapter at the turbo's. Is it supposed to be shaped like this? Ive seen two pictures online of this part, and both of those show a perfect oval opening. However, this part doesn't appear to be cracked, or repaired, it simply looks bent. Since its carbon fiber, I don't think it would have bent :)
    Current:
    '13 S7 (Innovation, B&O, LED's, AWE Exhaust, RS-Grille) -- '12 FJ Cruiser (Heavily modded) -- '14 QX80
    Gone but not forgotten:
    2014 Porsche Carrera S -- 2014 Toyota 4Runner -- 2002 Acura TL-S (My first 'luxury' car)
    Jan 27 2016
    Denver
    Current:
    Feb 11 2013
    C7 S6
    North San Diego
    my first awe intake deformed like that after less than 200 miles, it took a while to get a replacement part. they blamed it on a bad batch or something. you can try to contact awe, but since you bought it second hand they probably will not offer you a warranty. gl.
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Jan 27 2016
    Denver
    Good to know. Thanks. Worse case, I might be able to get the original purchaser to get the part for me. :). He's a forum member. I've also noticed the air inlet part is deformed slightly under the rubber and clamp also. That one in not as concerned about. I just don't want a gap opening at the turbos with unfiltered air! Thanks again.
    Current:
    Feb 11 2013
    C7 S6
    North San Diego
    glad to help, yours looks a lot better than mine, the clear coat/resin was actually cracking on mine to the point where i had to stop driving the car until i got the replacement lol. hopefully it won't be too much headache to get it replaced.
    Jan 27 2016
    Denver
    Wow. Hopefully AWE helps out. I'll post here to update everyone.
    How'd you discover the issue? This was under the rubber, and I'm guessing the guy who sold it to me never noticed, as the rubber was still tight on the part from he took the intake off the car.
    Current:
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    My buddy who has S7 and that intake had similar problem. He got his intake replaced as well.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
