Results 1 to 26 of 26
    Senior Member Two Rings Joey9's Avatar
    Mar 16 2015
    2009 Audi A4 Avant & Matching Trailer // 2009 Audi A4 Sedan APR Ko4, FBO, APR Stage 3+
    Rochester, MI
    B8 A4 Avant: HELP!!! Turbo Bearing Failing
    Took my car into the dealership to have some stuff checked out, and when I went to go pick up the car they said the turbo bearing was failing. Im not quiet sure that that means but I am looking into a new turbo. What could have caused this? I am Eurodyne Stage 2 if that makes a difference. The dealership quoted me $1400 for a new turbo, 7.5 hours of labor equalling ~$2400, plus or minus $200 for miscellaneous fasteners, fluids etc. Im assuming something is bound to go wrong and it will probably cost around $2600 or possibly even more. My only thought is that the ko4 kit is $2400 new from CTS Turbo. Should I just buy the ko4 kit and install it myself or just go with the ko3 from the dealership? I am wanting to upgrade to ko4 in the future so i feel like now is the time to do it. Will the ko4 hold up better/longer than the ko3? Would there be any advantages going ko4 instead of ko3 in this situation besides power? I would be tuning with the Eurodyne ko4 file if I did go ko4. Any help would be greatly appreciated, I'm trying to get all of this figured out before the European Experience car show in Savannah. If you have any questions feel free to ask. Thanks! Joey
    Heres a pic of my car. Instagram @joeyjacobss
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Are you able to install your own k04? CTS kit also means HFC and DP work. In your shoes I would do the k04.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Frankenturbos are $1500 and bolt right up. Also you already have Eurodyne which comes with a Frankenturbo tune which is amazing.
    Just saying.
    Also what's all that stuff under your car?
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I'd definitely use the same funds to upgrade, regardless of whether you go Frankenturbo, K04, EFR, etc.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    ^ This. If X fails, upgrade X with a better aftermarket component. K04 time.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Mar 16 2015
    Rochester, MI
    Quote Originally Posted by pierreb View Post
    yeah i am, and it comes with a catless dp already
    Quote Originally Posted by lettuce View Post
    Just saying.
    is there anything better about the frankenturbo verses the ko4?
    and what stuff under my car? I have some shitty underglow under my front bumper that doesnt work anymore haha and the white stuff under my side skirt is just worn out plastidip haha
    Quote Originally Posted by adamazing View Post
    is there more reliability out of the ko4 or any of the other turbos over the ko3?
    Quote Originally Posted by Project Quattro View Post
    thats what i was thinking
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by Joey9 View Post
    I can't speak to the Frank/EFR options out there, but remember that the K04 was used by Audi in previous models.
    2020 A4 allroad
    NH
    There's no data available to show k04 reliability is improved over k03 that I've seen.
    Yes CTS kit comes with pipe. Not sure if you were aware it wasn't just a turbo install but also some piping will be required.
    Mar 16 2015
    Rochester, MI
    what efr would i be looking to get for my car? I can't find any kits for it. and does anyone know if eurodyne has a tune for the efr?
    2020 A4 allroad
    NH
    The apr stage 3 kit is EFR.
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    Mar 16 2015
    Rochester, MI
    When will they be releasing it?
    Mar 24 2014
    Arin hasn't confirmed a date yet. That said, although the gains will be bigger, their stage 3 kit is likely to be far more expensive than a K04.
    May 25 2011
    Norway
    Well your turbo is pushed to the limit now, that's why it's failing. If you ask the same from a larger turbo such as a k04 or f23 they will probably last a lot longer.
    But you want more power from the new turbo of course, and then it's a matter of how much you push that one. Ultimately, all turbos fail. Since most tuned cars are unique in setup, it's hard to get any useful reliability data on the available replacement turbos.
    Both turbos will probably last fine if the software is good. If eurodyne has a good tune and the f23 is that much cheaper, that certainly sounds like a good alternative.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    @joey9
    Have you ever dyno'd your Eurodyne Stage 2?
    I would agree with what others say here, if you already have eurodyne, go K04 or F23L rather than putting another weaker turbo in.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    hey OP...side note...ill be at European experience with a bunch of audizine people (like 25 of us)....should be a good time!
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Active Member Two Rings Brad Kane's Avatar
    Nov 16 2011
    Calgary, Alberta
    I had the same issue with our 2011 Avant, it was cheaper to go with the APR K04 vs. the OEM K03 replacement. Performance is great.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    You can also find a cheap used k03 for substantially less money than the upgrade if you don't want to go for more power. I personally am going k04 on my car.
    My 2009 A4 Prem+ Build thread
    Mar 16 2015
    Rochester, MI
    Quote Originally Posted by kvitrafn View Post
    That makes sense, and yeah ill look more into the f23
    Quote Originally Posted by blbroo View Post
    @joey9
    i have not, but yeah if i get a new turbo hopefully it will be the ko4 or f23
    Quote Originally Posted by SleeperCar View Post
    Id love to meet up with you guys! email me at joeyjacobsss (at) gmail (dot) com and we can get in touch! Im also a photographer so i could take some pics, rollers, or rig shots
    Quote Originally Posted by Brad Kane View Post
    thats good news to hear on my end haha, hopefully i can upgrade
    Quote Originally Posted by Lambda13 View Post
    yeah i thought about that but i want to go ko4 of f23 anyway so i didn't see a point in putting a ko3 in when later down the road I'm just going to put a bigger turbo in anyway
    Mar 16 2015
    Rochester, MI
    Update: When i took it to the dealership, the mechanic said that they could "hear" the bearing failing and that "if you put a stethoscope up to the turbo you'd be able to hear the bearing failing" but when me and some friends went to listen to it we couldn't hear anything. The did not specify if they took off the turbo to check which is what some friends said is the only way to check. I can almost guarantee they didn't take the turbo off because my car was only gone for about 2-3 hours. Is just listening to the turbo even a proper way to determine if the bearing is failing? Could the techs just not of ever heard a tuned car and thought it was the bearing failing? Im starting to think my turbo is fine and they didn't diagnose it correctly. Any thoughts on this?
    2020 A4 allroad
    NH
    My thoughts are that you should drive it until the turbo actually fails. Usually that comes with a CEL, a dentist drill sound, exhaust smoke or any combination of those three things. Seems fishy to me.
    Jun 26 2009
    Bremerton WA
    You could unbuilt the cat from the turbo. Remove the transmission/ cat support bolt and undo the downpipe to resonator clamp. Slide the cat back a few inches. You can then get to the turbine shaft end see of it has end play or wobble. Spin and check for smoothness.
    Mar 16 2015
    Rochester, MI
    thats what i was thinking, but i don't want it to blow on me when I'm in an unfortunate spot haha
    Quote Originally Posted by van462 View Post
    maybe i could have a shop do that
    - - - Updated - - -
    Anyone have any thoughts on this?
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Yes, you can indeed diagnose a bad bearing by sound...if it is bad enough. The car when taken on a test drive will sound like there is a dentist drill in the engine bay.
    If it were me, I would pick up an IHI ko3 CHRA on ebay and just swap it in, have it balanced and be on my way for $200
    Mar 16 2015
    Rochester, MI
    Quote Originally Posted by b6Hate4 View Post
    it doesnt sound like a dentist drill in the engine bay, so should i assume my turbo is fine?
    2020 A4 allroad
    NH
    Find an independent local mechanic that can confirm the diagnosis. Frankly I would keep driving the car until it actually breaks like I said.
