Results 1 to 18 of 18
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Fluidamper revisited
    Hey guys,
    Been 6+ months now since the B8 Fluidamper release. Just wanted to check if any more members here besides the few that have posted when I searched, have any updates or further reviews on their purchase. Was it worth it? Any complaints? All my readings point to mostly positive reviews in other platforms. From preventing engine damage due to high output chatters to smoother engine operation and dynoed increases in upper range torque and HP. Even proven dyno on a Ko4 GTI. And right now its priced pretty well on USP.
    Anywho, may bite the bullet; im just looking for updated inputs regarding this upgrade.
    Oz
    PS: came from an EC Rotamass pulley that may have caused my front main seal to leak giving me a P2187 code for awhile until I went back to stock and changed the seal, from my readings the Fluidamper should NOT put the crank seal at risk.
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Personally, I didn't want to fuck with something aftermarket that could cause such big catastrophic engine failure for a few horses
    Even on the fluidampr
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Sep 30 2014
    Buffalo, NY
    Smellie,
    My name is Ivan and I work for Fluidampr. I am confused by your statement. Why do you suggest an aftermarket Fluidampr could cause such a big catastrophic engine failure?
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    :popcorn:
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Apr 21 2015
    Quote Originally Posted by inc4203 View Post
    Smellie,
    Oops! idk why it cut off on "Even on the fluidampr"
    I meant to say, even on the fluidampr i'd rather spend 400-450$ on something else for power, like a water/meth kit.
    Sep 15 2012
    San Diego
    Quote Originally Posted by OzeyeruZ View Post
    Hey guys,
    Oz
    I was in that same boat, I had the EC Rotomass pulley and it killed my engine seal multiple times and gave me the evap code until i changed it out. I've been running it for about 8 months now and haven't had a code since. Unfortunately, I can't tell you about noticeable differences between the stock pulley and the FAMPR because a lot changed inbetween (k04, tunes, airbox, etc) but I can tell you that it is a very solid piece of material, is very similar in size to the oem part, runs much smoother than the ECRM pulley due to the harmonic balancing and hopefully, gives me a few more feet of torque at higher levels (maybe???).
    ____________________________
    Nems
    Mods:
    CTS K04 Turbo | CTS HFC | AWE Exhaust | AWE FMIC | AWE DP | APR Stage II | EC Rotamasss LW Pulley | KW V3 COs | Adv.1MV2 20"x10" | H&R Sways | Okada Ign Coils
    May 24 2013
    Thanks Guys! Sounds like a solid product throughout many platforms since mid 00's from my google searches, especially in higher HP cars. For the price I read the smoothness alone seems adequate.
    Oz
    Nov 28 2015
    Montreal, QC
    it's available nnow ? i thought it was still in developpement.
    May 24 2013
    Quote Originally Posted by waxxonMTL View Post
    Been available sine July of 2015. Lol
    Sep 01 2012
    Edmonton
    Personally i haven't had an issue with the EC rotomass pulley, I bought it on the first GB when released. That being said i'm still interesting in getting a Fluidampr one when i switch turbos.
    2018 RS3 Panther Black
    Nov 28 2015
    Montreal, QC
    okay sorry.. i thought the s4 and a4 had the same crank pulley. obviously not lol.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    If you want to change out your crank pulley / balancer, this is the one to go with without having to worry about potentially messing up the harmonics of the rotating assembly.
    I just replied in a different thread about the Eurocode one; as an engine builder, the only way I would go with the Eurocode is if I rebalanced the whole rotating assembly 'with' that pulley. I don't care how long (miles or time) they tested that product on a few cars. All it takes is one engine's tolerance to be quite different (the tolerances for the engine have a range; each build will vary from engine to engine) with this pulley and you have a recipe for an issue. Those variances exist simple because of mass production and QA finish efforts. It's not like we're talking about a Bentley or Ferrari, hand built engine here .
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    May 24 2013
    Thanks for the reply. As stated previously USP has a great price on it right now for $370 shipped!.
    Oz
    Sep 01 2012
    Edmonton
    Quote Originally Posted by Allowencer View Post
    Thanks for the input.
    Jun 12 2013
    Oz
    hrm.. that's almost worth getting right now since my motor is still in pieces LOL
    Build Thread
    Senior Member Two Rings NRigs's Avatar
    May 21 2015
    Ma
    Someone should totally get one and send a DIY install along with some feedback after driving around a bit.
    2020 SQ5 Prestige | IE Stage 1 | BMC Air Filter | 034 Transmission Insert
    Gone:
    2011 335xi | Custom Tune | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
    2014 A4 | CTS K04 l Euro Code HFIP l TR11 l 034 Mounts & Inserts l ECS Luft-Technik l DV+ l LED Light Swap l R8 Coils l NGK plugs l RS4 Grille l Niche Targas M129 l Continental DWS 06 l CR-15
    Apr 02 2016
    none
    i would trust a fluidamper better than any other
    my supra has had one since day one started out with 800HP now up to 1200hp
    supras do have a problem with the front seal as well but its the oil pressure that literally pushes the seal out
    so what people started doing is pinning the seal so that it does not slide out
    May 24 2013
    The Fluidampr definitely smoothed out my idle and engine pull on the highway. Feeling the engine working less when doing WOT especially on E85.
    Oz
