Results 1 to 40 of 67
    Feb 15 2016
    Cambridge,Ontario
    What jobs that seem so simple turn out so miserable.
    I think this has the potential to be a good thread. As people provide feedback to short cuts and easier ways it could make the community better DIY ers.
    I will kick things off...
    1. Fog lights on the car ...
    found it a pain for what it was , the hardest part peeling and putting back the fender liner so I could get to those two speed nuts holding back the front of the car. seems simple enough ..
    2. the new style HPFP with the rubber line as opposed to the banjo.
    the banjo on the early car was easy .. correct angle and done .. that F'ing rubbr hose on the new cars that seems like its glued on and those stupid clamps you just cant get an angle on as it seems they are always pointed the wrong way. Total frustration and a lot of swearing .... how can it take longer to get this line off than a vacuum pump and timing housing ... grr...
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    How about a 0awg power wire run through the firewall... How hard could that be? Right?
    06 Dolphin Gray tip 2.0T
    GIAC Xplus | USP Testpipe | RevMotoring Springs | 19X8.5/9.5 Niche Targa | pioneer 80PRS | Taramp's HD1200, HD8000, HD10000 | 18-Sound 6's | B&C 8's | Audiocontrol Three.1, Audiocontrol Epicenter | Clarion EQS746, MCD360
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Quote Originally Posted by L'Audi View Post
    Holy crap that took so long.
    Feb 15 2016
    Cambridge,Ontario
    That was done on my car when I got it .. he pushed it through a cut he made in the a/c firewall diaphragm and ran it behind the glove box. ( one of the first things I ripped out )
    1976 Yamaha XS 360
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Cleaning the interior of my car when I bought it. The previous owner was a female and she was hot but my god was she a pig. the cup holder had a weird mixture of coke and pennies that had turned into a hockey puck. also her makeup was all over the steering wheel, dash, and other places.... took me a good 6 hours to clean her mess. I thought it would be quick and easy... Like an onion, you peel back layers to find the nastiness. on a good note, I found a broken ipad she had in the trunk of the car. lots of nudes!!!!!
    Dec 23 2011
    Test Pipe install went from easy to pain in the ass when I dropped a bolt down the jhm downpipe. Rather than disassemble the downpipe to mid-section I used a coat hanger with neodymium magnets taped on the end to fish it out of the bifurcation. That was fun lol...
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Must not have an s line. For lights are the easiest thing I've even done on this car. Pull grill off, unscrew, done.
    I'll go with the thermostat. Coming from a B5 when I figured my thermostats was bad I thought okay that's easy. WRONG! Way more complex on the B7.
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    If its the line I'm thinking of, i didn't even need to remove it to get to the cam follower. Was able to pull it out with it still on.
    May 20 2010
    EVERYTHING. I feel that anything you think is easy on the car turns out to be deceptive. Not to say it's not doable, but there's always that catch. Like reinserting the sunroof accordion...
    Aug 28 2014
    Calgary, Canada.
    When you snap the upper control arm pinch bolt lol .
    May 20 2010
    Quote Originally Posted by Danaldson View Post
    I've been lucky that's never happened. I did, however, have the upright disintegrate around where the upper control arms bolt in. On both sides. Guessing galvanic corrosion or something like that.
    Aug 28 2014
    Calgary, Canada.
    oh wow! never heard of that happening. Im lucky that i was able to get it to a shop and they punched it out in 20 mins.
    Feb 15 2016
    Cambridge,Ontario
    .. now that's what im talking about ..
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    I even look at that bolt and it scares me . I would never think going in " this should be easy !! .. but I have already wrestled with it on my C-5
    1976 Yamaha XS 360
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I'm surprised people have trouble with the newer non-banjo bolted HPFP. It's a breeze but I don't disconnect the soft lines, just the hard line's bolt.
    Installing my DV+ was ridiculous for 3 bolts. My hands felt like it went through a 1000 cuts because of a fraying steel line for the intercooler? And all the awkward angles to get in there from the bottom blind for greasy bolts.
    What I thought would be a 15 minute job turned to hours...
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    May 20 2014
    e92
    Timing belt/thermostat.
    Everything went smooth until I reached the triple star bolt on the thermostat hard line. Didn't know it was triple star and had me stumped for 2 hours, trying various allen and torx bits.
    Its the damn M5 triple square bolt. @mec came to rescue.
    Senior Member Three Rings Mlambrecht17's Avatar
    Aug 11 2014
    Minnesota
    My headlights have been a major pain in the ass, from taking everything apart and painting it, to restoring the lenses. I have a lot of work ahead of me
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by trj View Post
    when I watched a mechanic on you tube do it he replaced them with hex screws to save the next guy .. great idea.
    1976 Yamaha XS 360
    Apr 06 2016
    Long Island, NY
    First time changing my cam follower (on my MK5)... Fuck a banjo bolt. What sick, twisted monster thought that was a good idea? At THAT angle too! [/End Rant]
    May 20 2014
    e92
    Yah, but you still need M5 to remove it the first time. I thought to replace it too, but with the right tool, its 30 seconds job. So, I just let it be.
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Quote Originally Posted by supple View Post
    Yes on the rubber hose for the HPHP. Dont worry about.. you dont have to take it all off. Just slide it to the side with the rubber hose still attached.
    lol and yes on the DV. It took me HOURS with my big hands and someone else just did it in 15mins and said it was a breeze
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Copen-cisco View Post
    yeah I figured out pretty quick who provides solid advice on jobs and who just wants to sound like the big shot and say everything is easy. I think my first job is to look on the side of my DV to see if I can make out whether its been upgraded to the latest style.
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    yup this is true , nothing like getting half way through a job and have to borrow a car to go to the store for the right tools ..
    1976 Yamaha XS 360
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Tools for everything. I replaced the spring style hose clamps with fuel injection clamps. Remote hose clamp pliers help and so do hose grip pliers.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Surprised nobody has mentioned the rear coolant flange. For me it wasn't even the flange itself, its the damn coolant pipes/hose clamps around it. Ive done two of these and found that the hose had bonded/melted to the hard line. Had to cut both of them off and replace them
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    May 20 2010
    Thank heavens I do not have that banjo bolt!
    - - - Updated - - -
    Quote Originally Posted by Low and Behold View Post
    I read the thread, and decided "nope" and took it to a shop. Book labor was 2.5 hours, but wound up taking them about 4 1/2 or so. Easily counted. But like I said, most things on this car are deceptive.
    Feb 15 2016
    Cambridge,Ontario
    I have the rear timing cover off as we speak .. and im staring down at that flange thinking " that STILL looks like a PITA and I can see it now" . it was done previously by the dealer but im thinking it may be due again soon ...
    1976 Yamaha XS 360
    Feb 21 2015
    Rip City
    The flange is easy. Its the plumbing coming out of it thats a PITA if I'm honest.
    I made good use of the camera on my iPhone by slipping it back there to see what i was up against. Good thing too, because the screws for the flange weren't what I thought they were. I think they were torx instead of triple square, or vice versa.
    You'll be thinking the whole time - "if only"... your hands were smaller, you had another inch of room, etc.
    Feb 15 2016
    Cambridge,Ontario
    yeah they are triple square .. now I just need to borrow a Chinese child worker from Steve Jobs I phone factory and ill be fine...
    1976 Yamaha XS 360
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Quote Originally Posted by miA4 View Post
    How has this thread gone on this long without someone calling this guy out on Rule #22?
    2018 A5 S-Line Manual
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by konarider94 View Post
    this...
    Jul 17 2015
    miami
    Isn't rule 22 only allowed when I reference my own GF?
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Post the nudes, you know for research purposes
    Jul 17 2015
    miami
    Quote Originally Posted by ZERO FRAME GRAB View Post
    If I still had them, I still wouldn't. goes against my moral code my good man. Although, they were used for science purposes.....
    Mar 03 2015
    Easton PA
    Headliner removal from B6 Avant, seemed like a cool project pull headliner and trim wrap in black suede. Reinstall.............still reinstalling by the way
    Mar 03 2015
    Easton PA
    Hey everybody look at this guy here with his fancy "morals"!!!!
    Jul 17 2015
    miami
    Hey! I fapped to them so these "morals" of mine aren't that great...
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Negative, it applies to any specific female you mention.
    Mar 24 2013
    Oakdale, CT
    I've done pretty much everything there is to do to my car at this point, up to and including building the engine and swapping it into the car without a second set of hands. The one thing that consistently frustrates me is trying to bolt the fucking oil return line onto the turbo. Every time, it takes way longer than it should and results in lots of swearing.
    -Adam
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    I just went through this ordeal with my avant because the headliner started to sag. Remove, reupholster and reinstall was truly a miserable job from beginning to end.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
